Hello,
I am trying to use the tool "Copy (Data Management)" from ArcMAP 10.5.0 to copy a Geodatabase from local drive (D:) to a network drive (Z:). and every time I got the following error:
ERROR 000260: Failed to copy D:\T\New File Geodatabase (4).gdb into Z:\2)GIS_and_Design\7)CrescentLink\CrescentLink_Users\Ahmad_Saleh\Ahmad_Saleh.gdb
Failed to execute (Copy).
But the unusual thing is when I go to the destination folder I am able to located this Geodatabase and also I can connect to it and see or edit the data inside, everything looks normal!.
The tool worked and copied the GDB to this location but it also throw the previous error!.
PS: I have full read/write permission on this network folder, which mean that the tool has the full permission to write at this folder!. The same tool works fine if I used it to copy from Local to Local folders, and fails if tried to copy from Network to Network Folder!.
Have anyone had this issue before ?
