Cannot export data from FC as FC or table
2715
7
06-28-2019 05:31 PM
forestknutsen1
When I attempt to export data from a table as a dbase file, text, or to a fgdb. I also cannot export it to a feature class in a fgdb. Every time I try I get an error.
The source feature class is in SDE.
I can display the data in ArcMap and I can view the attribute table without any problem. I can also view the data with sql without any problem. And I can export the data with FME fine.
Suggestions for troubleshooting?
Tags (1)
forestknutsen1
Esri support suggested this patch:
ArcGIS Desktop 10.6.1 Exporting Data From a Layer Patch
This fixed the problem.
JoshuaBixby
MVP Esteemed Contributor
What tools are you using or have you tried and what steps are you taking?
forestknutsen1
Just the standard right-click on the FC in the TOC and export. I have also tried the export function from the attribute table.
JoeBorgione
What license are you using?
That should just about do it....
forestknutsen1
Advanced
by Anonymous User
Not applicable
@forest knutsen One tool is there feature class to feature class conversion in Arc Catalog toolbox .
Use this.
forestknutsen1
Thanks for the suggestion Avinash. That does in fact work. But the users still want the menu based option....
forestknutsen1
