Branch Versioning for DBO owned geodatabase
8592
10
01-29-2019 04:01 PM
VishApte
I have an Enterprise Geodatabase in SQL Server 2016 and I am building Utility Network using ArcGIS Pro 2.2. My geodatabase is created as DBO owned schema and not as SDE owned schema. When I set geodatabase connection properties with versioning type set to Branch, it sets the version name as DEFAULT and owner as "SDE" and does not let me choose different owner. I do not have SDE log-in or SDE user in the SQL Server database. Will any functionality be affected if I start using branch versioning without SDE user in the database?
Cheers,
Vish
SavageTrimble
DBO Schema support for branch versioning?  Data store support for branch versioning?
