Auto-increment with Attribute Rules
2217
06-06-2019 04:06 AM
AlfonsoDodero
Hi everyone,
I'm experimenting with using of Attribute Rules on my Enterprise Geodatabase. I'd like to use this useful feature to auto-increment an ID code according to my specific scheme:
I'd need that for each new entry in a table, the field with the id-code (a "long type" field) increments by 10 units with respect to the maximum value already existing in the table. I've tried this expression
Max ($ feature.name_of_the_field) + 10
but without result. The RDBMS is Microsoft SQL Server.
Can someone help me?
Tags (1)
ColinWerle1
Hi Alfonso,
I believe a related conversation is happening over at Auto-Increment Field within SDE. There should be some information throughout that thread that you may find valuable to your workflow.
Colin
AlfonsoDodero
Thanks Colin, so it's not possible to get the desired result through Attribute Rules and I have to act on the SQL Server, right?
