Are you planning on replacing an SDE SDK application? If so, what technology will you use?
906
04-26-2017 02:36 PM
KenGalliher1
If you’re still maintaining applications written in the ArcSDE Java or C API you may already know you’re getting close to the end of the code base’s life cycle.  As a support analyst, I have been seeing a spike in calls regarding migrating from the SDE SDK by using native database spatial types with SQL and ArcObjects.  How are you approaching your migration?
