arcpy.Copy_management is throwing a runtime error
3000
07-03-2019 05:30 PM
MayKao1
I want to copy a table from SDE to a local file gdb.
Assuming
  SDEworkspace is the full path to the SDE database
  outGDB is the full path to the local file gdb
Here is the code:
   arcpy.env.workspace = SEDworkspace
   tableName = "MasterStreetName"
   outTableName = "{}\{}".format(outGDB, tableName)
   arcpy.Copy_management(tableName, outTableName)
Runtime error  Traceback (most recent call last):   File "<string>", line 1, in <module>   File "c:\program files (x86)\arcgis\desktop10.6\arcpy\arcpy\management.py", line 4314, in Copy     raise e ExecuteError: ERROR 000840: The value is not a Data Element.
This script used to work and other features are copied correctly, just seem to have problem with tables.
LanceCole
May,
One notable item is a possible typo in your script, "arcpy.env.workspace = SEDworkspace" may need to be "SDEworkspace".  Or is this just a typo in your post?
MayKao1
It's just a typo in the post.
NeilAyres
What do you mean by this :
The variable SDEworkspace should contain a full path and name of a sde connection file.
MayKao1
It has the full path name of a sde connection file.
I just posted pseudo code.
LanceCole
May,
1) Does the error message listed correspond to your sudo code?  In particular the File “<string>”, line 1 relate to the arcpy.env.workspace = SDEworkspace line 1 in your sudo code.
Here is the code:
   arcpy.Copy
2) is this running as a stand-alone script or in ArcGIS.  I have seen this error when coping a feature when it is active in the TOC from desktop scripts.
