Hopefully you can point me in right direction.
Environment: ArcPro 3.0.3 connecting to SQL 2019 enterprise geodatabase ver 11.0.0.3.0
I have had a user called stclairGIS that has been data owner for years. Example of a dataset in question here (but its happening throughout database) is listed in cataloge as <STCLAIRGIS.MiscellaneousAnno100> but when I go to manage, it says its not data owner (see attachment) im at a loss as to how to "reassert it as owner" if thats even a thing.
This is preventing me from upgrading annotations , calculating statistice, reindexing etc...
I FOUND IT !!!! - I FOUND IT !!!! - I FOUND IT !!!!
In SSMS for that user Server Roles , I had processadmin checked. When I unchecked it, this resolved my problems.
Thanks a million for kick starting my brain!
Can you provide a screen shot of your connection properties?
When was the last time that this worked for you?
Thanks for that information. That is weird behavior.
Does that user have "dbowner" role in SQL Server? Or did the permissions get changed during the upgrade?
Can you create a new feature class (empty) without any issues?
In the connection, can you put the username in ALL CAPS?
Random question: Are you using Pro Basic license?
Is the annotation versioned? (https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/upgrade-dataset.htm)
Thanks!
That could cause it. Glad you found out the issue.
