Append GP fail on Oracle geodatabase
937
07-07-2022 06:45 AM
mody_buchbinder
I try to use the Append GP tool in Pro to add record from source table to target table.
The tables are identical and I get the error:
ERROR 160228: The user does not have permission to execute the operation.
If I try to write a small python program that uses insert cursor I get similar problem.
The strange thing is that the same Append works for ArcMap with the same connection.
More then that I can run DeleteRows on this table without any problem.
Even more I can add records using pro just one by one.
Any ideas??
MichaelVolz
Esteemed Contributor
What kind of permissions are set for the db connection?  I wonder if the permission requirements have changed between ArcMap and Pro.
mody_buchbinder
I am using the same connection file in Pro and ArcMap.
It saved on my local disk not as part of Database connection or the aprx dir.
