Add an incremental, unique ID
18425
21
01-02-2020 09:21 AM
JoeBorgione
This is a topic that's been around for as long as I can remember.  The attribute assistant provided a couple methods to do this: autonumber, generate id, and there us a tool called Add Incrementing ID field but it is limited to database tables, not GEOdatabase tables; if an object id is present, the tool won't work.
Is there a method or tool available in ArcGIS Pro 2.4.3 that will autoincrement a field in an enterprise geodatabase table and/or feature class?
Tags (1)
GretaParis
The errors I am receiving: 001487 & 001369
kkopanias
I am using the following exression in the attribute rule and in Pro it works just fine:
'acethn'+$feature.OBJECTID
Nevertheless in a Web App in Enterprise, I get the following result: e.g. acethn-1
Instead of the $feature.OBJECTID I get the value -1.
