Python error "ZIPCODES does not exist"
1368
01-13-2019 07:07 PM
JeremiahGbolagun1
I encountered the error " ZIPCODES does not exist" when I ran below code using PyScripter. Can you please help by letting me know where I am wrong.
import arcpy, sys
from arcpy import env
# Set the workspace environment
env.workspace = r"C:\EsriPress\GISPython\Data\SampleData.gdb"
# Check the spatial references for a feature class in the workspace
fcName = "ZIPCODES_poly"
fcNameProperties = arcpy.Describe(fcName)
print fcNameProperties.spatialReference.name
DanPatterson_Retired
Is it ZIPCODES or ZIPCODES_poly that you are looking for.
Check to see if it indeed does exist by loading it up into arcmap. and examining its properties for the source,
check its name, and the case of the text is important
JeremiahGbolagun1
I am looking for the ZIPCODES_poly and not ZIPCODES.
Then the error message is wrong...  " ZIPCODES does not exist" , you might want to edit the post, but a restart of python and rerun the script may be in order as well
