Error Inspector
4450
12-19-2018 06:21 AM
EdwardBlair
Am trying to use the Error Inspector to review/repair Utility Network topology errors, however when I click the tool to panel only shows the message "Please select a map that contains error layers".    Is this referring to the error layers associated with my Utility Network?    If so, these are present (below).
I must be missing something.  Any pointers would be appreciated.
Thx,
Ed
Tags (1)
PaulLeBlanc1
Ed,
The error inspector does not work the Utility Network error layers. If you hover over the tooltip of the error inspector:
Validate and fix geodatabase topology—ArcGIS Pro | ArcGIS Desktop
EdwardBlair
Paul -
Thanks for the clarification. Do we get pretty much the equivalent
functionality by examining attributes of the Utility Network error layers?
Ed
PaulLeBlanc1
Yes, the attributes on the error layers store that information.
Error features—ArcGIS Pro | ArcGIS Desktop
Error feature management—ArcGIS Pro | ArcGIS Desktop
TrevorAllen2
Is it on the Road Map to enable Error Inspector to work with the Utility Network?
