Reverse geocoder in Flutter
1324
12-06-2024 04:38 AM
mobiletec2024
Hi everyone,
When I click on an intersection, the reverse geocoder function does not show me the intersection between the two streets. What do I need to do to see this information?
Thanks
MichaelBranscomb
Esri Frequent Contributor
Are you using your own custom Locator dataset (for example, instead of the ArcGIS World Geocoder)? What's the value of the property supportsIntersections property - LocatorInfo class - arcgis_maps library - Dart API?
Thanks
MichaelBranscomb
Thanks
mobiletec2024
Hi Michael, thanks,
I'm now using SDK version 200.7, and I've finally solved the problem.
Thanks for this new version.
