OAuth window appears circularly on Android emulator
6513
13
01-09-2025 03:07 AM
EgorFedorov
I have configured my app to sign in to ArcGIS online via OAuth according to sample. When I try to access portal (namely, get token) on Android emulator, I experience the following behaviour.
  1. Window with standard ArcGIS web view asking for username/password appears
  2. I fill required info and click "Sign In" button
  3. Window disappears but immediately appears again with empty UN/PW fields and without any errors
  4. If I fill UN/PW fields and click "Sign In" again, I see step #3 repeated again
  5. If I click "Cancel", I see step #3 repeated again
  6. If I click "X" button in top left, it returns back to my application without any error in log
This is very confusing behaviour. Nevertheless, token in received correctly and is available in my code.
Here is what I see in Flutter log:
Launching lib/main.dart on sdk gphone64 x86 64 in debug mode...
Running Gradle task 'assembleDebug'...
✓ Built build/app/outputs/flutter-apk/app-debug.apk
D/FlutterLocationService(25127): Creating service.
D/FlutterLocationService(25127): Binding to location service.
Debug service listening on ws://127.0.0.1:54747/7nhbvLo_1Ck=/ws
Syncing files to device sdk gphone64 x86 64...
D/ProfileInstaller(25127): Installing profile for com.esri.[my-app-id]
I/PlatformViewsController(25127): Using hybrid composition for platform view: 0
D/CompatibilityChangeReporter(25127): Compat change id reported: 236825255; UID 10191; state: ENABLED
E/EGL_emulation(25127): eglQueryContext 32c0 EGL_BAD_ATTRIBUTE
E/EGL_emulation(25127): tid 25127: eglQueryContext(2146): error 0x3004 (EGL_BAD_ATTRIBUTE)
I/MapViewRenderer(25127): Starting pulse
I/flutter (25127): Getting token
I/flutter (25127): Creating OAuthUserCredential
D/EGL_emulation(25127): app_time_stats: avg=3309.65ms min=164.96ms max=6454.35ms count=2
D/EGL_emulation(25127): app_time_stats: avg=3305.84ms min=166.88ms max=6444.81ms count=2
D/EGL_emulation(25127): app_time_stats: avg=1767.54ms min=59.52ms max=6441.73ms count=4
I/MapViewRenderer(25127): Stopping pulse
D/EGL_emulation(25127): app_time_stats: avg=243.07ms min=17.80ms max=1832.81ms count=9
D/EGL_emulation(25127): app_time_stats: avg=243.33ms min=14.82ms max=1836.10ms count=9
D/EGL_emulation(25127): app_time_stats: avg=242.64ms min=19.78ms max=1825.41ms count=9
I/flutter (25127): Getting token info
I/flutter (25127): accessToken: 3NKHt6...
I/MapViewRenderer(25127): Resumed by user. Texture view available: true
W/OpenGLRenderer(25127): Failed to choose config with EGL_SWAP_BEHAVIOR_PRESERVED, retrying without...
W/OpenGLRenderer(25127): Failed to initialize 101010-2 format, error = EGL_SUCCESS
E/OpenGLRenderer(25127): Unable to match the desired swap behavior.
D/EGL_emulation(25127): app_time_stats: avg=24751.84ms min=24751.84ms max=24751.84ms count=1
D/EGL_emulation(25127): app_time_stats: avg=24763.88ms min=24763.88ms max=24763.88ms count=1
D/EGL_emulation(25127): app_time_stats: avg=27904.54ms min=157.61ms max=55651.45ms count=2
D/EGL_emulation(25127): app_time_stats: avg=27900.98ms min=150.63ms max=55651.33ms count=2
D/EGL_emulation(25127): app_time_stats: avg=18624.16ms min=93.41ms max=55642.82ms count=3
Notes:
  1. OAuth credentials are valid and works well with ArcGIS Maps SDK for Kotlin/Swift.
  2. I use currently released version of ArcGIS SDK for Flutter (200.6.0+4426), the latest Flutter SDK (3.27.0), and the latest Dart version (3.6.0).
  3. This workflow works correctly for iOS
  4. Android simulator versions are 12 and 14
Here is the video describing what's happening.
(view in My Videos)
EgorFedorov
I've already posted some code to GH to show minimum example, but decided to check Troubleshooting Android section for 'flutter_web_auth_2' package readme. It helped to solve my problem. Actually, it looks like 'flutter_web_auth_2' issue, not ArcGIS SDK one.
They recommend to:
  • Add 'android:launchMode="singleTop"' for OAuth activity declaration in 'AndroidManifest.xml' (but in my experience, it doesn't make any sense)
  • Remove 'android:taskAffinity' from 'AndroidManifest.xml' (totally, even ones declared for other activities)
This helped partially: my app after that behaves similar to "Authenticate with OAuth" sample. So, in conjunction with your advice to add 'preferPrivateWebBrowserSession: true' param, it works as expected.
Nevertheless, it raises additional questions.
  1. Why Flutter creates manifest file with  `android:taskAffinity=""` ? What's it role and how critical it is for general app functionality?
  2. What is the purpose for 'preferPrivateWebBrowserSession' in general? Should'n it be set to 'true' by default (or even internally without any possibility to change)?
PaulSturm
My first guess is that there is a mismatch with the "redirect url", described in the "Redirect URL" section on this page: https://developers.arcgis.com/documentation/security-and-authentication/user-authentication/oauth-cr...
That needs to be configured properly on the server side, and it needs to match two places in your client code. It needs to match the "redirectUri" parameter to your "OAuthUserConfiguration" object, and it needs to be set up properly in your "AndroidManifest.xml". It needs to be an "<activity>" tag under your "<application>" tag, like this:
<activity android:name="com.linusu.flutter_web_auth_2.CallbackActivity"
android:exported="true">
  <intent-filter android:label="flutter_web_auth_2">
    <action android:name="android.intent.action.VIEW" />
    <category android:name="android.intent.category.DEFAULT" />
    <category android:name="android.intent.category.BROWSABLE" />
    <data android:scheme="my-ags-app" />
  </intent-filter>
</activity>
In this example, my redirect url is "my-ags-app://auth", and the "scheme" setting in AndroidManifest.xml is just the "my-ags-app" part.
This configuration is necessary so that Android can move the user from the browser login page back to your application. Also note that you should have a unique redirect uri for each app installed on a single device -- if you have multiple apps with the same redirect uri, Android won't be able to navigate back to the proper app.
PaulSturm
For comparison, here is how OAuth is configured in our Sample Viewer's "Authenticate with OAuth" sample:
https://github.com/Esri/arcgis-maps-sdk-flutter-samples/blob/main/lib/samples/authenticate_with_oaut...
https://github.com/Esri/arcgis-maps-sdk-flutter-samples/blob/main/android/app/src/main/AndroidManife...
(Note that your "clientId" and "redirectUri" will be unique to your application.)
EgorFedorov
Thanks for answer, but looks like this is not the case. I have configured AndroidManifest.xml according to sample, it has the following lines:
<activity
        <data android:scheme="rn-ags-examples" />
    </intent-filter>
</activity>
And here are redirect URLs configured on portal:
Also, I use correct clientId and redirectUri when creating OAuthUserConfiguration instance (just double-checked it).
PaulSturm
I wonder if the "/" (slash) at the end matters? The sample code uses "my-ags-app://auth", without the trailing slash. I see that your portal configuration uses a trailing slash in two cases, but not the third. I'm not sure if that matters, but it might.
Another thought is this: does the device you're testing on have more than one installed app using the same redirectUri (or perhaps just the same "scheme" in the Android.xml)? We've run into problems when that happens. Perhaps to test this theory you could try running on a second Android device. If the problem only occurs on some but not all Android devices, then that would indicate there's something unique to the device.
And then lastly, does the "Authenticate with OAuth" sample work on this particular device?
EgorFedorov
I've removed trailing slash in all cases, removed all my apps from emulator and re-installed the app I test. I've even created a new simulator w/ Android 14. No success for any try: oauth window still appears circularly.
Running the latest sample from GH has the following results (checked both with my own oAuth configuration and one provided with sample).
  1. Open "Authenticate with OAuth" sample.
  2. It loads basemap automatically and opens web view for UN/PW after some delay
  3. I fill UN/PW fields and click "Sign In". App returns to the map and displays webmap layer as expected
  4. If I click Android hardware Back button, it goes to the list of samples, and, with another Back button click, to web view with UN/PW
  5. If I fill UN/PW in window appeared in step 4, it goes back to the list of samples or (observed several times) become appearing circularly again
Please take a look at video attached.
Note: I have Android API 35 installed, so I had to update Gradle to 8.3 and AGP to 8.1.4 so that I can build and run samples.
(view in My Videos)
PaulSturm
Hmm that's very confusing. Can you post the code for your app from the very first screen recording? The one with the "Get token" button. And drop in the OAuth configuration from the "Authenticate with OAuth" sample (so you don't have to post your own OAuth configuration).
From the new video, it looks like the Sample Viewer is behaving a little better than your example app. I'm not sure why that is. Possibly because the Sample Viewer navigates to a separate page when you select it from the list. Or there might be some other relevant difference in how the challenge handler is set up.
It looks like the Sample Viewer only gets into trouble when you use the hardware back button to return to the login view. I'm going to look for a way to close the login view after a successful login. The implementation on iOS doesn't behave like that, so maybe there's something Android-specific we should be doing.
EgorFedorov
They recommend to:
PaulSturm
1. This is a good question and I don't know the answer. I'm going to write up an issue internally to keep track of this. Hopefully it is a bug in "flutter_web_auth_2" that they can fix. In the mean time, we should probably add the troubleshooting steps for "singleTop" and "taskAffinity" to our documentation.
2. There's definitely a bug in how we implemented "preferPrivateWebBrowserSession". We accidentally tied it to the App Activity history stack (specifically, the "FLAG_ACTIVITY_NO_HISTORY" flag). We'll fix this internally so that you don't have to set "preferPrivateWebBrowserSession" in the future. I'm sure this fix will be in the next release (200.7).
EgorFedorov
I've looked through Android docs on 'android:taskAffinity' attribute, and they says:
The task that the activity has an affinity for. Activities with the same affinity conceptually belong to the same task, to the same "application" from the user's perspective.
To specify that the activity doesn't have an affinity for any task, set it to an empty string.
The name of the default affinity for an application is the namespace set in the build.gradle file.
So, in our case it is important for MainActivity and 'com.linusu.flutter_web_auth_2.CallbackActivity' to have the same nonempty 'taskAffinity' attribute. In that case both of them will belong to the same task and behave in default way (closed by 'Back' button click). Checked this setting 'android:taskAffinity="xyz.yyy"', and circular behaviour gone.
But why is it set to empty string by Flutter? Why they don't want 'MainActivity' to belong to any task? In fact, this is intentional solution from Flutter team described in related issue. They are trying to mitigate StrandHogg Attack. And this mitigation caused influence to 'flutter_web_auth_2'.
Looks like this is not possible to overcome this on app side in any way other then setting 'android:minSdkVersion="30"' (i.e., supporting Android 11+, as recommended by Android team).
  1. Possibly, update 'flutter_web_auth_2' to version 4 can help? This comment recommends updating to 4.x for similar issue.
  2. Have you tried any other OAuth packages/solutions?
  3. Is it possible to close OAuth activity manually from app code or arcgis_maps package code (maybe via some native calls to Kotlin/Java)?
Also posted a question for 'flutter_web_auth_2'.
