D/EGL_emulation( 6006): app_time_stats: avg=67.14ms min=62.52ms max=71.44ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=66.56ms min=61.40ms max=69.99ms count=16
D/EGL_emulation( 6006): app_time_stats: avg=66.59ms min=63.22ms max=69.40ms count=16
D/EGL_emulation( 6006): app_time_stats: avg=66.77ms min=53.06ms max=79.76ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=66.58ms min=63.62ms max=73.60ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=66.41ms min=60.46ms max=73.36ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=66.44ms min=60.44ms max=70.78ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=66.29ms min=61.04ms max=70.95ms count=16
D/EGL_emulation( 6006): app_time_stats: avg=65.89ms min=62.27ms max=69.78ms count=16
D/EGL_emulation( 6006): app_time_stats: avg=66.10ms min=62.51ms max=70.53ms count=15
D/EGL_emulation( 6006): app_time_stats: avg=59.75ms min=19.24ms max=101.00ms count=17
D/EGL_emulation( 6006): app_time_stats: avg=55.58ms min=30.39ms max=107.62ms count=18
I/MapViewRenderer( 6006): Egl objects disposed
E/libEGL ( 6006): call to OpenGL ES API with no current context (logged once per thread)
I/Choreographer( 6006): Skipped 40 frames! The application may be doing too much work on its main thread.
D/EGL_emulation( 6006): app_time_stats: avg=66.92ms min=22.41ms max=714.19ms count=20
Restarted application in 6,483ms.
I/PlatformViewsController( 6006): Using hybrid composition for platform view: 0
F/libc ( 6006): Fatal signal 8 (SIGFPE), code 1 (FPE_INTDIV), fault addr 0x781b96b50c80 in tid 6006 (.flutter_arcgis), pid 6006 (.flutter_arcgis)
Build fingerprint: 'google/sdk_gphone64_x86_64/emu64xa:15/AE3A.240806.036/12592187:user/release-keys'
Revision: '0'
ABI: 'x86_64'
Timestamp: 2025-09-15 10:25:01.250505100+0000
Process uptime: 555s
Cmdline: com.example.flutter_arcgis
pid: 6006, tid: 6006, name: .flutter_arcgis >>> com.example.flutter_arcgis <<<
uid: 10212
signal 8 (SIGFPE), code 1 (FPE_INTDIV), fault addr 0x0000781b96b50c80
rax 0000000000000100 rbx 0000781c0ae5e000 rcx 0000000000000002 rdx 0000000000000000
r8 0000000000000100 r9 0000000000000080 r10 0000000000000000 r11 0000000000000213
r12 0000000000000000 r13 0000000000000002 r14 0000000000008a11 r15 0000000000000100
rdi 0000000000000000 rsi 0000000000000000
rbp 0000000000000080 rsp 00007ffdb8108eb0 rip 0000781b96b50c80
69 total frames
backtrace:
#00 pc 0000000000049c80 /vendor/lib64/libGLESv2_enc.so (GL2Encoder::s_glBindBufferRange(void*, unsigned int, unsigned int, unsigned int, long, long)+880) (BuildId: cad4d9b6f0ed175f224d403d48dddb9b)
#01 pc 0000000001ea5fa9 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#02 pc 0000000001ea5813 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#03 pc 0000000001eb34fa /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#04 pc 0000000001eb4013 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#05 pc 0000000001eb1800 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#06 pc 0000000001eb1475 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#07 pc 0000000001eb1003 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#08 pc 0000000001e4cfd2 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#09 pc 0000000001e52595 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#10 pc 0000000001f75793 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#11 pc 0000000001dc7b40 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#12 pc 0000000001dc7a78 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#13 pc 0000000001dc7ae9 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#14 pc 00000000022ac357 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#15 pc 00000000022ae9c3 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#16 pc 0000000001efc0b4 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#17 pc 0000000001efbb37 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#18 pc 0000000001efa80f /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#19 pc 0000000001efb29f /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#20 pc 0000000001efd21b /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#21 pc 0000000001efad18 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#22 pc 0000000001efaa5b /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#23 pc 0000000001f0b242 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#24 pc 0000000001a4ccec /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#25 pc 0000000001a523e8 /data/app/~~MpiOYRZhhAluHPBspzdVDg==/com.example.flutter_arcgis-LSJwjkUoOx4tt1sMtk02MA==/base.apk!libflutter.so (offset 0x69b0000) (BuildId: 0b6730385c3c28b2181d83a2970fb133c136ab53)
#26 pc 00000000000136d6 /system/lib64/libutils.so (android::Looper::pollOnce(int, int*, int*, void**)+1862) (BuildId: f128755c26519c61f5cd218576eff285)
#27 pc 00000000001825e3 /system/lib64/libandroid_runtime.so (android::android_os_MessageQueue_nativePollOnce(_JNIEnv*, _jobject*, long, int)+35) (BuildId: 74e467b22a4c3107eac51948743c9977)
#28 pc 00000000001e41ce [anon_shmem:dalvik-jit-code-cache] (offset 0x2000000) (art_jni_trampoline+158)
#29 pc 000000000006e3c4 [anon_shmem:dalvik-jit-code-cache] (offset 0x2000000) (android.os.MessageQueue.next+388)
#30 pc 000000000006d835 [anon_shmem:dalvik-jit-code-cache] (offset 0x2000000) (android.os.Looper.loopOnce+197)
#31 pc 00000000003fe0c2 [anon_shmem:dalvik-jit-code-cache] (offset 0x2000000) (android.os.Looper.loop+306)
#32 pc 000000000022cffb /apex/com.android.art/lib64/libart.so (art_quick_osr_stub+27) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#33 pc 0000000000630588 /apex/com.android.art/lib64/libart.so (art::jit::Jit::MaybeDoOnStackReplacement(art::Thread*, art::ArtMethod*, unsigned int, int, art::JValue*)+472) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#34 pc 00000000002340cb /apex/com.android.art/lib64/libart.so (void art::interpreter::ExecuteSwitchImplCpp<false>(art::interpreter::SwitchImplContext*)+18955) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#35 pc 000000000022d2e5 /apex/com.android.art/lib64/libart.so (ExecuteSwitchImplAsm+5) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#36 pc 000000000020c024 /system/framework/framework.jar (android.os.Looper.loop+0)
#37 pc 00000000005f1de9 /apex/com.android.art/lib64/libart.so (art::interpreter::Execute(art::Thread*, art::CodeItemDataAccessor const&, art::ShadowFrame&, art::JValue, bool, bool) (.__uniq.112435418011751916792819755956732575238)+505) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#38 pc 00000000005f85f7 /apex/com.android.art/lib64/libart.so (art::interpreter::ArtInterpreterToInterpreterBridge(art::Thread*, art::CodeItemDataAccessor const&, art::ShadowFrame*, art::JValue*)+103) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#39 pc 00000000005f92d9 /apex/com.android.art/lib64/libart.so (bool art::interpreter::DoCall<false>(art::ArtMethod*, art::Thread*, art::ShadowFrame&, art::Instruction const*, unsigned short, bool, art::JValue*)+2313) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#40 pc 0000000000233364 /apex/com.android.art/lib64/libart.so (void art::interpreter::ExecuteSwitchImplCpp<false>(art::interpreter::SwitchImplContext*)+15524) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#41 pc 000000000022d2e5 /apex/com.android.art/lib64/libart.so (ExecuteSwitchImplAsm+5) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#42 pc 00000000001d6138 /system/framework/framework.jar (android.app.ActivityThread.main+0)
#43 pc 00000000005f1de9 /apex/com.android.art/lib64/libart.so (art::interpreter::Execute(art::Thread*, art::CodeItemDataAccessor const&, art::ShadowFrame&, art::JValue, bool, bool) (.__uniq.112435418011751916792819755956732575238)+505) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#44 pc 0000000000987e6e /apex/com.android.art/lib64/libart.so (artQuickToInterpreterBridge+958) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#45 pc 000000000022b77c /apex/com.android.art/lib64/libart.so (art_quick_to_interpreter_bridge+140) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#46 pc 00000000002124b6 /apex/com.android.art/lib64/libart.so (art_quick_invoke_static_stub+806) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#47 pc 0000000000474c24 /apex/com.android.art/lib64/libart.so (art::ArtMethod::Invoke(art::Thread*, unsigned int*, unsigned int, art::JValue*, char const*)+228) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#48 pc 00000000008745ea /apex/com.android.art/lib64/libart.so (_jobject* art::InvokeMethod<(art::PointerSize)8>(art::ScopedObjectAccessAlreadyRunnable const&, _jobject*, _jobject*, _jobject*, unsigned long)+2218) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#49 pc 00000000007d00b7 /apex/com.android.art/lib64/libart.so (art::Method_invoke(_JNIEnv*, _jobject*, _jobject*, _jobjectArray*) (.__uniq.165753521025965369065708152063621506277)+39) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#50 pc 000000000022b5eb /apex/com.android.art/lib64/libart.so (art_quick_generic_jni_trampoline+219) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#51 pc 0000000000212154 /apex/com.android.art/lib64/libart.so (art_quick_invoke_stub+756) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#52 pc 0000000000474bf5 /apex/com.android.art/lib64/libart.so (art::ArtMethod::Invoke(art::Thread*, unsigned int*, unsigned int, art::JValue*, char const*)+181) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#53 pc 00000000005f92f3 /apex/com.android.art/lib64/libart.so (bool art::interpreter::DoCall<false>(art::ArtMethod*, art::Thread*, art::ShadowFrame&, art::Instruction const*, unsigned short, bool, art::JValue*)+2339) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#54 pc 0000000000233101 /apex/com.android.art/lib64/libart.so (void art::interpreter::ExecuteSwitchImplCpp<false>(art::interpreter::SwitchImplContext*)+14913) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#55 pc 000000000022d2e5 /apex/com.android.art/lib64/libart.so (ExecuteSwitchImplAsm+5) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#56 pc 00000000001d226c /system/framework/framework.jar (com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run+0)
#57 pc 00000000005f1de9 /apex/com.android.art/lib64/libart.so (art::interpreter::Execute(art::Thread*, art::CodeItemDataAccessor const&, art::ShadowFrame&, art::JValue, bool, bool) (.__uniq.112435418011751916792819755956732575238)+505) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#58 pc 0000000000987e6e /apex/com.android.art/lib64/libart.so (artQuickToInterpreterBridge+958) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#59 pc 000000000022b77c /apex/com.android.art/lib64/libart.so (art_quick_to_interpreter_bridge+140) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#60 pc 00000000008196f0 /system/framework/x86_64/boot-framework.oat (com.android.internal.os.ZygoteInit.main+2704) (BuildId: bc047a67a4076b80992fbdfabdfba12acbd1924a)
#61 pc 00000000002124b6 /apex/com.android.art/lib64/libart.so (art_quick_invoke_static_stub+806) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#62 pc 0000000000474c24 /apex/com.android.art/lib64/libart.so (art::ArtMethod::Invoke(art::Thread*, unsigned int*, unsigned int, art::JValue*, char const*)+228) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#63 pc 0000000000875126 /apex/com.android.art/lib64/libart.so (art::JValue art::InvokeWithVarArgs<_jmethodID*>(art::ScopedObjectAccessAlreadyRunnable const&, _jobject*, _jmethodID*, __va_list_tag*)+518) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#64 pc 0000000000726e9a /apex/com.android.art/lib64/libart.so (art::JNI<true>::CallStaticVoidMethodV(_JNIEnv*, _jclass*, _jmethodID*, __va_list_tag*)+586) (BuildId: 62338b1c62e3991543c9b8b8bae2b361)
#65 pc 00000000000dcf68 /system/lib64/libandroid_runtime.so (_JNIEnv::CallStaticVoidMethod(_jclass*, _jmethodID*, ...)+136) (BuildId: 74e467b22a4c3107eac51948743c9977)
#66 pc 00000000000f2fb0 /system/lib64/libandroid_runtime.so (android::AndroidRuntime::start(char const*, android::Vector<android::String8> const&, bool)+928) (BuildId: 74e467b22a4c3107eac51948743c9977)
#67 pc 0000000000004706 /system/bin/app_process64 (main+1638) (BuildId: 2919fb70658f9ff2e805cbbbdd33a33b)
#68 pc 0000000000057c82 /apex/com.android.runtime/lib64/bionic/libc.so (__libc_init+114) (BuildId: eb58b4d427279994f00c0e1818477e4f)
Lost connection to device.
Exited.
