Problem with closing database
2675
01-25-2012 02:49 AM
ArturRedzko
I made a C wrapper dll to expose simple API for using SDK 1.1 and noticed that opening more than one layer from the same database ( .gdb using client app) causes hanging upon CloseGeodatabase execute.  If there is only one layer opened, it can be closed without any problems. My question is do I have to share the same "connection to database" for different clients using dll to open any layer or can I open database for each request and return new handle?
Regards
Artur
LanceShipman
Are you closing the tables before attempting to close the geodatabase?
ArturRedzko
Yes. I'm closing and clearing all resources and handles taken from database. The problem occurs even if I do the simplest scenario:
- initialize dll for one client
- open a database test.gdb
- initialize dll for second client
- open the same database test.gdb
- try to close a database for first client
It's enough to hang the app (inside dll) on CloseGeodatabase. I noticed that inside the test.gdb directory a lock file is begin created. Sometimes after a long time of waiting the databases close. But in most cases I must kill the app. I tried to repeat the same situation using a simple console app that is using the same code as my dll bypassing the C wrapper and it works fine. I can create multiple access to the same database and close them without problems. So it looks like a dll issue.
LanceShipman
Can you post your code. We have C++ tests for this and have seen no problems.
ArturRedzko
Problem solved. I found this in your readme.txt :
KNOWN ISSUES:
* Concurrent access from Windows and Linux clients to the same File GeoDatabase can corrupt data. This combination should be avoided.
so I made a shared connection for the same database and it works fine now.
Hope to see new update 1.2 with working spatial index soon.
Regards
Artur
