Must construct xml to create workspace or featureclass ?
3431
08-24-2011 07:13 AM
hexuezhou
Hi, I want to create workspace by  File GDB API, but I found only construct xml before do this .
It is not like ArcObjects createFeatureClass Function conveniency .
Am I wrong ? Thank you!
LanceShipman
You must write XML to create feature datasets, feature classes or tables. Examples are supplied under samples\XMLsamples. The creation of a File Geodatabase does not require XML and is a simple call to geodatabase::creategeodatabase.
hexuezhou
Hi ,lshipman
Thank you for your reply.
In my option , create xml schema will slow down coding effective .
for one dataset have many Table and FeatureClass to created,so we must construct difference xml string
for this .
Why doing in this way?
