Embedding Graphics as BLOBS
2014
10-06-2011 06:48 AM
adamestrada
All,
Is it possible to embed a graphic inside a FGDB? I am interested in storing image chips to use as quick reference information in the DB and am stuck on how to accomplish this. Any ideas would be greatly appreciated. I just came across this guy...http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Adding_raster_datasets_as_attributes_i...
Is there a way to do this programatically?
Regards,
Adam
VinceAngelo
Esri Esteemed Contributor
While file geodatabases can store rasters, the FileGDB API is documented as not supporting them.
You can certainly store any bytestream in a BLOB column, but that will not generate a RASTER type
column.  ArcObjects can be used to load rasters programatically.
- V
