Building C# examples
2675
11-08-2011 03:36 AM
CarlosOrtiz
Ok,  I have tried to build the examples on two development machine and I get this error on both.
Error 1 'Esri.FileGDB.Row' does not contain a definition for 'Geometry' and no extension method 'Geometry' accepting a first argument of type 'Esri.FileGDB.Row' could be found (are you missing a using directive or an assembly reference?) C:\FileGDB_API_VS2010_1_1\samplesC#\Display\Form1.cs 115 43 Display
Am I missing something?  I installed OpenTK to overcome that error.  I have tried compiling as x86 and x64.  Same errors.
The systems are both using VS2010 and the operating systems are Windows XP Version 2002 SP3 (32-bit) and Windows Server 2008 R2 Datacenter  Service Pack 1 (64-bit).
LanceShipman
Are you using VS2010 Express or Professional? .NET Framework 4.0?
CarlosOrtiz
Visual 2010 Premium and .Net Framework 4.  All I did was unzip and compile after installing OpenTK.
LanceShipman
There is an error in the sample.
Replace:
PointShapeBuffer geometry = row.Geometry;
With:
PointShapeBuffer geometry = row.GetGeometry();
