Time slider for images
2561
5
01-16-2025 10:22 AM
Labels (2)
JV_
I have a collection of high-resolution drone images stored locally on my computer (not in the cloud) that I would like to add to my website, which is built using ArcGIS Experience Builder.
Is there a widget available in ArcGIS Experience Builder that can provide a time slider functionality similar to the one in ArcGIS Pro for satellite imagery?
JeffreyThompson2
MVP Frequent Contributor
https://developers.arcgis.com/experience-builder/guide/timeline-widget/
Take a look at the Timeline Widget.
GIS Developer
City of Arlington, Texas
KateDoughty1
Yes, it's the Swipe Widget under Map Centric tools.
Marshal
Timeline Widget supports image layers as data sources starting at ExB Dev 1.15.  That said, my testing indicates it must be published as a mosaic which requires ArcGIS Image Server.
I'd love for someone to tell me I'm wrong, but that is what I discovered in my limited testing.
https://community.esri.com/t5/arcgis-experience-builder-ideas/support-for-image-service-in-experienc...
Time Slider Instant App can support image services that are not published as mosaic datasets.  Maybe a solution if ExB is not a requirement.
JV_
@MarshalThank you for your response. I believe the best option would be to create an Instant App and embed it within ExB. However, I'm having difficulty creating a Time Slider with images in the Instant App, as it seems to require a published layer. Does this mean I need to save all the images as attachments in a layer and then publish it? If so, is not that different from the ExB...
Marshal
Yes, you need to publish the imagery layer to share over the web.  Typically, that would entail publishing to ArcGIS Online or ArcGIS Enterprise.
ArcGIS Online:
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/publish-hosted-imagery-layers.htm
ArcGIS Enterprise:
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/web-image-layer.htm
