Overview
This widget brings ArcGIS Pro style map printing into ArcGIS Experience Builder without needing a print service. You share a layout from ArcGIS Pro as a layout file (.pagx), import it once in the widget settings, and the widget rebuilds that page in the browser against your live map: map frame, title and text, north arrow, scale bar, legend, pictures, and lines.
https://github.com/brianmcleer/print-advanced-widget
This is the first release and I am putting it out as a beta. I would like the community to run it against real layouts and real maps before I call it stable. If you can try it and send feedback, that would be a big help. See "What I would like help testing" below.
Note: Requires ArcGIS Experience Builder Developer Edition 1.19 or 1.20 (React 19). 1.18 and earlier are not supported.
Note: The widget dependencies install automatically with the standard "npm install" in the EB client folder. No separate install needed.
Note: Import an ArcGIS Pro layout file (.pagx) in the widget settings to define the page. There is also an optional Esri print service path if you would rather use a server side ExportWebMap service.
What Can This Widget Do?
- Reproduces an ArcGIS Pro .pagx layout in the browser (map frame, text, lines, north arrow, scale bar, pictures, legend), calibrated against real Pro output.
- Exports PDF and SVG as true vector, plus PNG32, PNG8, JPG, GIF, TIFF, and EPS. No print service required.
- Optional Esri print service path (an ExportWebMap URL) for server side layouts, which also adds AIX.
- Print area preview drawn on the map, so you see what will print before you export. Keep the current scale, keep the current extent, set a fixed scale, or pick one from a list, with a lock toggle.
- 12 north arrow styles and 9 scale bar styles shown as thumbnails, plus a Layout default option.
- Output coordinate system (WKID) to print in a different projection than the map.
- Author, copyright, and attribution tokens. Legend and map only export. Custom fonts by URL, including a Google Fonts import.
- Recent exports list, and XML import and export of the whole configuration.
- Administrator control over the default settings, which formats are offered, and which runtime controls end users see.
What I Would Like Help Testing
- Your own ArcGIS Pro .pagx layouts. Import one and tell me how close the output is to Pro. If something is off, sending the .pagx and a screenshot lets me reproduce it.
- The print area preview and scale lock, across different basemaps and projections.
- The Esri print service path, pointed at your own ExportWebMap URL.
- Output coordinate system, printing in a WKID different from your map.
- Custom fonts by URL and the Google Fonts import in PDF output.
How to report back: comment here or open an issue on GitHub. Include your EB version, your browser, and any browser console errors. A short screen recording helps a lot (I use OBS Studio).
Changelog:
8/12/2026:
Fixed legend items rendering as gray squares in Experience Builder 1.21. The newer ArcGIS Maps SDK renders the Legend widget behind shadow DOM, which hid symbol swatches from the print harvest; swatch extraction now pierces shadow DOM, supports the new arcgis-legend component, and automatically falls back to building symbols from layer renderers if extraction ever comes up short. No changes needed to your maps or layouts. Thank you to @ncramer11 for reporting via GitHub.
7/23/2026:
Updated the Map Switcher widget for Experience Builder 1.21 to resolve TypeScript editor errors, including React component typing and immutable configuration imports. The widget version was also bumped and the latest release is now available on GitHub.
7/17/2026:
Legend system overhaul
- Legend now reads the live Legend widget on the page, exactly what the user sees: layer order, group nesting, visibility, and sublayer hierarchy, with a Legend source setting to bind a specific widget or detect automatically
- High-resolution symbology: map service swatches fetched from the REST legend at 288 DPI and matched contextually to legend rows; vector swatches supersampled; symbols draw aspect-true (line swatches stay thin, markers stay round), no more stretched or blank patches
- New adjacent panel placements (right, left, bottom): the map frame shrinks to make room, panel width is content-driven with balanced columns, the panel trims around layout furniture like corner logos, and the authored frame border wraps map and legend together so Pro-designed compositions stay intact
- Multi-page legends: an "Additional pages (PDF only)" placement paginates the legend across as many full sheets as needed at full font size, with continuation headings and the same sheet size and orientation as the map page
- Smart fit intelligence: the widget measures the actual legend live and warns with specifics ("87 items; about 23 will not fit"), auto-defaults to additional pages when items would drop (one-click revert, and it reverts itself as layers are toggled off), and flags any truncated export on the result row
- Long labels wrap to three lines before an honest ellipsis; widow control keeps headings with their items
- Legend on/off toggle available to admins per layout in settings and to end users in the widget, plus a runtime placement selector
Scale bars
- Full 12-style catalog including Alternating (ticked), Line with labels below, and center-axis Scale line, each with an accurate preview tile
- True Pro dual scale bars: Double alternating and Double hollow always print two measurements sharing the zero point, with the second unit auto-selected as the natural complement (miles-feet, meters-kilometers) and overridable
- Collision-proof unit labels in every style and both single and dual modes
Usability and workflow
- Runtime user overrides for legend placement and grid type, gated by admin visibility controls
- Author and Copyright fields now always print, in a clean cartographic credits line in the bottom page margin when the layout has no text element consuming them
- "Apply to all layouts" buttons for overview, grid, and legend settings; re-importing a .pagx now updates the matching layout in place and preserves its settings
- Live print-extent preview tracks the legend panel, map-only mode, and explicit pixel dimensions before the first export
- Performance pass (concurrent legend build and capture, swatch caching, parallel extraction) and a WCAG accessibility pass across all controls
07/09/2026:
Add @ncramer11 as contributor. Resolved below issue.
The problem: setting.tsx gets its dropdown lists (formats, north arrow styles, scale bar styles and units) from runtime/lib/pdfRenderer.ts. That file also imports four esri/* modules, so those get pulled into the compiled settings bundle. It seems the builder page cannot always load esri modules at the moment the settings panel opens. When that happens the settings module fails with window.require is not a function in the console, and the builder shows the widget and the settings panel stuck on the loading spinner.
Commit 1: Moves those dropdown lists into a new file, src/printConstants.ts, which imports nothing from esri. pdfRenderer.ts re-exports them so the runtime code does not change at all (widget.tsx is untouched), and setting.tsx now imports from the new file. With that, the settings bundle no longer references esri and loads fine. It also shrank from about 3.3 MB to about 350 KB. I left a comment in printConstants.ts explaining why it needs to stay esri-free.
Commit 2: Swaps the seven indentLevel={1} props on SettingRow for indented. My editor flags indentLevel because it is not in ExB 1.20 typings. No difference in behavior, so feel free to skip this one if you would rather.
- New: Overview inset map. Turn on a zoomed-out locator map with an extent indicator in any corner of the map frame. Configured entirely in the widget settings, no changes to your Pro layout needed.
- New: Grids and graticules, ArcGIS Pro style. Choose a graticule (latitude/longitude, works in any coordinate system), a measured grid (map units), or a reference grid (A-1 index). Line styles, colors, intervals, and labels are configurable, and labels include hemisphere suffixes and halos for readability over imagery.
- New: Runtime toggles let users turn the inset and grid on or off per print.
- Improved: Map capture limit is now automatic based on the graphics card, so large layouts print sharper. The export progress line reports the effective DPI.
- Improved: Long URLs in attribution text now wrap instead of running off the page.
- Fixed: "1 inch equals 0 miles" on layouts using miles at city scales.
07/02/2026:
Initial beta release. Posted to GitHub. Looking for feedback before I mark it stable.
