Mailing Labels Custom Widget
17548
52
05-28-2025 07:41 AM
Mailing Label Widget Overview
This widget is designed to enhance mailing label management within the ArcGIS Experience Builder ecosystem. It offers seamless integration with map layers, advanced selection and drawing tools, and supports multiple label output formats including CSV and PDF.
https://github.com/brianmcleer/mailing-labels-widget
Note: Requires Optional install of jsPDF on client folder, running npm install jspdf
Note: Input service needs to be a Feature Layer (editing capabilities not required)
Developer Edition Configuration
(view in My Videos)
End User Interaction
(view in My Videos)
What Can This Widget Do?
Original capabilities (from core logic):
  • Select and configure map layers to use as data sources for labels.
  • Map fields to specific mailing fields (name, address, city, state, zip).
  • Draw shapes (point, polyline, polygon, rectangle, circle) to select areas for labels.
  • Generate labels in CSV and PDF formats with customizable label templates (Avery 5160–5164).
  • Font size options for printed labels.
  • Automatically disables Esri’s popups and highlights while active to focus on drawing and selection.
  • Clear selection areas and restore map behavior when the widget is closed.
Enhanced capabilities in this version:
  • Dynamic field mapping options that populate from selected layers.
  • Buffering options (distance and unit) for drawn geometries to expand selection areas.
  • Clear selection graphics and highlight management with fallback visualizations for feature selection.
  • Responsive label previews and customizable font size and label formats.
  • Error handling and messaging for failed queries or drawing operations.
  • Map view and layer management to handle disconnected or delayed map loading gracefully.
  • Interactive user messages (success, warning, error) displayed for actions like selection, generation, or errors.
Configuration Options
  • Map Widget Selection: Choose the map widget to connect to.
  • Layer and Field Mapping: Select a feature layer and assign fields to mailing label fields.
  • Geometry Selection: Enable selection by click, draw, or both; configure a buffer for drawn areas.
  • Label Format and Font: Choose from multiple Avery formats and set the font size.
  • Output Options: Generate mailing labels as CSV or open a print-ready PDF.
Changelog:
07/23/2026:
  • Made compatibility fixes for Experience Builder 1.21 to clear TypeScript editor errors without changing the widget’s functionality.
06/03/2026:
  • Added package.json so jsPDF installs automatically with the standard "npm install" in the EB client folder. No separate jsPDF install needed.
05/21/2026:
05/06/2026:
  • Address search — type an address, the map zooms to it and drops a pin, then you can grab the parcel at that spot
  • Print labels button — skips the download step and opens the print dialog directly
  • Sort options — sort labels by name, city, state, or ZIP
  • Partial-sheet support — pick up where you left off on a half-used Avery sheet by clicking the slot you want to start at
  • Live label preview — see what the first label will look like before you print, with your real data and current format/font
  • Three more Avery formats — 5165, 5167, 5168
  • Smaller font sizes — added 5pt and 6pt so text actually fits on the tiny 5167 labels
  • Geocode URL - Set your geocoding service in settings
  • UI Updates
04/03/2026:
  • Implement idea from @AmyDuquesnoy about being able to add remove a selected feature after original selection area is drawn.
02/24/2026:
  • Integrate to grab selection from Custom Draw widget and pass to mailing labels (can be enabled/disabled in settings), See video at Advanced Draw Widget
02/12/2026:
  • Had a call come in from a realtor asking if they could select multiple parcels using a multipoint selection. Added multipoint selection as a pick option.
02/02/2026:
  • No longer maintaining 1.18 version.
  • Show original graphic vs buffer in different colors
  • Add option to widget to remove duplicates and empty records (both on by default)
12/10/2025 (for 1.19 version only):
  • Theme Typography Update – All widget text now uses Experience Builder’s Theme Typography for consistent styling.
  • Accessibility Improvements – Added multiple WCAG-compliant updates across widgets for better usability and accessibility.
11/13/2025: Breaking changes between Developer Edition 1.18 and 1.19:
Upgrading ArcGIS Experience Builder Widgets from 1.18 to 1.19: Breaking Changes
Experience Builder 1.19 introduces two critical breaking changes that prevent widgets built for 1.18 from loading. First, the WidgetState enum has been removed from 'jimu-core', requiring developers to replace WidgetState.Opened with the string literal "OPENED" in widget lifecycle methods. Second, and more significantly, the jsx() function signature has changed to align with React 17+'s new JSX transform—children must now be passed as a children property within the props object rather than as separate function arguments. This means jsx('div', {props}, child1, child2) must be rewritten as jsx('div', {props, children: [child1, child2]}) throughout the entire render method. Every jsx call in your widget needs updating, with all child elements explicitly specified in the children prop (e.g., jsx('h2', { style: {...}, children: 'Title' })). While this is a substantial refactoring effort, it brings Experience Builder in line with modern React standards and is a one-time migration requirement for the 1.18 to 1.19 upgrade path.
I have posted both a 1.18 and a 1.19 version in this update to work on both versions.
10/14/2025: Resolved BUG integrating widget in Experience that uses multiple maps.
08/01/2025: Enhanced address type management and UI adaptation
  • Added dual address type support: Widget now supports both Physical Mailing Address and Owner Address configurations with separate field mappings and optional separate data layers
  • Added conditional UI display: Radio button selection automatically hides when only one address type is enabled in settings, providing a cleaner single-purpose interface
  • Added automatic selection clearing: When switching between address types, any existing selections are automatically cleared to prevent data confusion, with user notification
07/23/2025: Tested widget on Developer Edition 1.18 that was released on 7/23/25 and widget functions as normal.
06/12/2025: Resolved bug that allowed for selection of up to 2,000 records but downloaded only 500. Limit now is 2,000 for both selection and CSV/PDF download.
05/28/2025: Automatic PDF Downloads with Smart Naming
Comments
Brian_McLeer
MVP Regular Contributor
Thank you CamMiller17. I am not sure why we can post on this article during the community freeze. The pop up suppression is by design, but I can look to add a feature in the settings to control pop up suppression there. I will not update this until after the Esri Community freeze as I don't want content to be lost. I will make an update after the freeze is over.
Brian_McLeer
CamMiller17 I have removed pop up suppression from being all the time in the widget to an option in the settings. The settings got a UI update and you can now import/export settings configuration to XML. I can't update the widget here, but you can grab the update on the GitHub URL. After the Community freeze, I will update this blog post.
Version history
Last update:
yesterday
Updated by:
Contributors
