Enhanced Measurement Widget
2767
25
11-07-2025 09:22 AM
Brian_McLeer
MVP Regular Contributor
5 25 2,767
Enhanced Measurement Widget for ArcGIS Experience Builder
Overview
This custom widget provides comprehensive measurement capabilities for ArcGIS Experience Builder applications. The widget was built on ArcGIS Experience Builder Developer Edition 1.18. The widget supports eight measurement tool types with extensive configuration options and export functionality. End users can create measurements and export them in multiple formats.
This is the first release of the widget and should be considered a beta version. Users are encouraged to provide feedback on bugs, requested enhancements, or suggested changes through comments on this post.
Required Dependencies
Before implementing this widget, install the following npm packages:
npm install @turf/turf
npm install jspdf
These dependencies provide geometric calculation functionality (Turf.js) and PDF export capabilities (jsPDF).
Developer Configuration (setting.tsx)
The setting.tsx file provides developers with a comprehensive configuration interface within Experience Builder. The configuration is organized into multiple sections that control widget behavior and appearance.
Map Connection
Developers select which map widget the measurement widget will interact with using the MapWidgetSelector component. This establishes the connection to the map view where measurements will be drawn.
Measurement Tools Configuration
The widget supports eight measurement tool types:
  • Point measurement (coordinate display)
  • Distance measurement (linear distance)
  • Area measurement (polygon area)
  • Circle measurement (radius and area)
  • Rectangle measurement (dimensions and area)
  • Triangle measurement (dimensions and area)
  • Freehand polyline (drawn distance)
  • Freehand polygon (drawn area)
Each tool can be individually enabled or disabled. Developers can configure:
  • Default tool selection on widget startup
  • Auto-start behavior to activate the default tool immediately
  • Continuous drawing mode for repeated measurements without tool reselection
  • Auto-clear behavior when switching between tools
Unit Configuration
Default measurement units are configurable for:
  • Linear units: meters, kilometers, feet, miles, yards, nautical miles
  • Area units: square meters, square kilometers, square feet, square miles, acres, hectares
Users can change units at runtime, but developers set the initial defaults.
Segment Labeling
For polyline and polygon measurements, segment labeling can be enabled to display individual segment distances. Configuration options include:
  • Enable/disable segment labeling feature
  • Default visibility state for segment labels
  • Auto-save segments option
  • Customizable segment label prefix (default: "Seg")
  • Segment label font size (8-24px range)
Display Features
Toggleable features that developers can enable:
  • Statistics panel showing count, total distance, and total area across all measurements
  • Tooltips during active drawing
  • Snapping to vertices and edges
  • Live measurement display while drawing
  • Total distance display for polyline measurements
Each feature includes a configurable default state (enabled/disabled on startup) and visibility toggle option (whether users can change the setting).
Coordinate Display
Coordinate format options include:
  • Decimal Degrees (DD): 34.0522, -118.2437
  • Degrees Minutes Seconds (DMS): 34°03'08"N, 118°14'37"W
  • Degrees Decimal Minutes (DDM): 34°03.133'N, 118°14.622'W
Developers can set the default format and configure whether coordinates display in Web Mercator or the map's spatial reference.
Import/Export Configuration
Export functionality supports four formats:
  • JSON: measurement data with geometry and metadata
  • CSV: tabular data with coordinates and measurements
  • GeoJSON: standardized geographic data format
  • PDF: formatted document with measurement summary
Developers can customize button text for import and export operations and configure default export format.
Symbol Styling
Symbol appearance is fully configurable:
  • Point symbol size (4-32px)
  • Line width (1-10px)
  • Polygon outline width (1-10px)
  • Fill opacity (0-100%)
  • Color palette: 10 customizable colors for different measurement types
Label Customization
Measurement label appearance can be configured:
  • Font size (8-24px range)
  • Label position (center, top, bottom)
  • Label background color
  • Label text color
  • Label visibility controls
User Interface Customization
Developers have extensive control over the UI:
  • Button layout: 2-column, 3-column, 4-column, or vertical
  • Compact mode for space-constrained layouts
  • Always show button text option
  • Show/hide widget title
  • Custom widget title text
  • Show/hide hint messages
  • Show/hide Clear All button
  • Show/hide icons on buttons
  • Custom text for empty state message
  • Custom measurements header text
Tool Button Text Overrides
Every measurement tool button has customizable text:
  • Point tool button
  • Distance tool button
  • Area tool button
  • Circle tool button
  • Rectangle tool button
  • Triangle tool button
  • Freehand line tool button
  • Freehand area tool button
Additional button text overrides include:
  • Clear All button
  • Undo button
  • Redo button
  • Show/Hide Statistics toggle
  • Show/Hide Segment Labels toggle
  • Show/Hide Tooltips toggle
  • Show/Hide Snapping toggle
  • Import button
  • Export All dropdown text
Dialog Customization
Confirmation dialogs have configurable text:
  • Clear All dialog title
  • Clear All dialog cancel button text
  • Clear All dialog confirm button text
Toggle Display Configuration
Developers can configure which toggle controls are visible to end users:
  • Show Statistics toggle
  • Show Segment Labels toggle
  • Show Tooltips toggle
  • Show Snapping toggle
Reset Functionality
A "Reset All Settings to Defaults" button allows developers to quickly restore all configuration options to their default values during development.
End User Functionality (widget.tsx)
The widget.tsx file implements the runtime functionality that end users interact with in published Experience Builder applications.
Measurement Tools
Users access measurement tools through a button grid. The active tool is highlighted, and clicking a tool button either activates it or deactivates it if already active. Tool functionality:
Point Tool: Single click places a point. Displays X,Y coordinates in the configured format and coordinate system.
Distance Tool: Creates polyline measurements. Each click adds a vertex. Double-click completes the measurement. Displays total distance and optionally shows individual segment distances with labels.
Area Tool: Creates polygon measurements. Click to add vertices, double-click to close the polygon. Displays total area and perimeter. If segment labeling is enabled, shows distances for each edge.
Circle Tool: Click to set center point, drag to set radius, click again to complete. Displays radius, diameter, circumference, and area.
Rectangle Tool: Click to set first corner, drag to opposite corner, click to complete. Displays width, height, perimeter, and area.
Triangle Tool: Three clicks create a triangle. Displays three side lengths, perimeter, and area.
Freehand Polyline: Click and drag to draw freely. Displays total distance. Release completes the measurement.
Freehand Polygon: Click and drag to draw freely. Release automatically closes the polygon. Displays area and perimeter.
Live Measurement Display
While actively drawing, a live measurement value appears at the cursor showing the current measurement in real-time. This provides immediate feedback before completing the measurement.
Unit Conversion
Each measurement includes dropdown controls to change display units without redrawing. Distance measurements can convert between all configured linear units. Area measurements can convert between all configured area units. Unit changes apply immediately to the displayed values.
Measurement Management
Completed measurements appear in a list below the tools. Each measurement entry shows:
  • Measurement type icon
  • Timestamp of creation
  • Primary measurement value with unit selector
  • Expand/collapse control for additional details
Expanded measurements display:
  • All calculated values (e.g., for circles: radius, diameter, circumference, area)
  • Coordinates (start/end points or vertices depending on geometry type)
  • Segment details for polylines and polygons
  • Export dropdown for individual measurement export
Segment Labels
When segment labeling is enabled, polyline and polygon measurements display individual segment distances directly on the map. Each segment shows:
  • Segment identifier (e.g., "Seg 1", "Seg 2")
  • Distance value with units
Segment labels remain visible and update if measurement units are changed. The expanded measurement panel lists all segments with start/end coordinates.
Statistics Panel
When enabled, the statistics panel displays aggregate information:
  • Total count of all measurements
  • Combined total distance from all polyline measurements
  • Combined total area from all polygon measurements
Statistics update automatically as measurements are added or removed.
Coordinate Display Modes
Point measurements and polyline/polygon vertex coordinates can display in two modes:
  • Web Mercator coordinates (WKID 3857)
  • Input spatial reference (map's coordinate system)
Users toggle between modes using a coordinate system selector. The widget handles transformation between coordinate systems automatically.
Undo/Redo Functionality
The widget maintains a history of all measurement operations:
  • Add measurement
  • Delete measurement
  • Modify measurement (unit changes, coordinate system changes)
Undo and redo buttons appear in the toolbar when history is available. History persists during the session but clears when the application is closed.
Import Functionality
The Import button opens a file selector. Supported import formats:
  • JSON: imports measurements with full metadata
  • GeoJSON: imports geometric features, creates appropriate measurement types
The widget validates imported data, transforms coordinates to the map's spatial reference if needed, and adds measurements to the list. An import success dialog displays the number of measurements imported.
Export Functionality
Users can export measurements individually or all at once. Export formats:
JSON Export: Creates a JSON file with complete measurement data including:
  • Measurement type
  • Geometry coordinates
  • Calculated values
  • Units
  • Timestamp
  • Metadata
CSV Export: Generates a tabular CSV file with columns for:
  • Measurement type
  • Primary value
  • Units
  • Coordinates (formatted string)
  • Timestamp
GeoJSON Export: Produces standard GeoJSON with:
  • Feature collection structure
  • Geometry in geographic coordinates (WGS84)
  • Properties with measurement values and metadata
  • Coordinate transformation applied automatically
GeoJSON exports can be re-imported in future sessions to restore measurements.
PDF Export: Creates a formatted PDF document using jsPDF with:
  • Measurement summary header
  • List of all measurements with values and units
  • Timestamp information
  • Coordinate details where applicable
Geometric Calculations
The widget uses Turf.js for accurate geometric calculations:
  • Distance calculations use geodesic methods for accuracy across large areas
  • Area calculations account for coordinate system distortion
  • Circle measurements use true geodesic circles, not map projection circles
  • Coordinate transformations preserve geometric accuracy
Clear All Functionality
The Clear All button removes all measurements from the widget and map. A confirmation dialog appears before clearing to prevent accidental deletion. Dialog text is configurable by developers in the settings.
Responsive Design
The widget adapts to different panel widths:
  • Button layout adjusts based on configured column count
  • Measurement list scrolls independently when content exceeds height
  • Dropdown menus position intelligently to avoid viewport edges
  • Compact mode provides optimized layout for narrow panels
Error Handling
The widget includes error handling for:
  • Module loading failures (ArcGIS JavaScript API modules)
  • Invalid import data
  • Geometric calculation errors
  • Coordinate transformation failures
Error messages display in the widget when operations fail, allowing users to understand and correct issues.
Changelog
3/26/26: Resolved issue for 1.20. Version 1.19 and 1.20 available for download. Please report any issues on this blog post.
3/25/26: DE 1.20 broke something in this widget, need to troubleshoot
2/26/2026:
  • Add custom measurement units via settings to appear in linear and area unit drop downs. Thank you @ncramer11 for idea and beta testing
  • Add import/export XML in settings to transfer/backup settings configurations
  • Updated settings UI to match more to Jimu standards
1/28/2026:
Add ability to edit vertices of existing measurements to update as needed.
1/25/2026:
UI BUG where show segment labels, show tooltips, and enable snapping would overrun at certain widths of widget container.
Before patch:
After Patch:
12/10/2025:
  • Theme Typography Update – All widget text now uses Experience Builder’s Theme Typography for consistent styling.
  • Accessibility Improvements – Added multiple WCAG-compliant updates across widgets for better usability and accessibility.
25 Comments
Brian_McLeer
Developer Edition 1.19 was released today (11/13). I tested the widget and everything looks to functioning the same as it was at DE 1.18.
eMosby
Hey @Brian_McLeer, really digging your work. I'm looking to test this widget out but don't see a file associated. Do you have a repo somewhere or am I just missing it?
Brian_McLeer
Thank you @eMosby. I did a minor update before the holidays and the ZIP must not have saved. It should be in the article now.
AdamGebhart
@Brian_McLeerAm I safe to assume these need to be run on Client?  Or is there another folder to run them on?
Brian_McLeer
@AdamGebhart correct, these get run on the client folder.
AdamGebhart
Thank you.
Brian_McLeer
1/25/2026:
Before patch:
After Patch:
AdamGebhart
@Brian_McLeer Hi Brian.  Can the user move vertices after the initial draw is complete?  Or do they have to delete and draw a new feature?
Brian_McLeer
Hello @AdamGebhart, below is the current functionality to edit vertices/shapes of measurements, which does not allow to go back and edit individual vertices. I could see this being a good enhancement, so I will look to add it shortly and post here when the ZIP is updated.
(view in My Videos)
AdamGebhart
Thanks @Brian_McLeer.  That video is very helpful.  I know our users would love to have that editing capability if you think it's possible.
Brian_McLeer
Thank you for the feedback and idea @AdamGebhart . It wasn't too much to add vertex editing.  I have updated the ZIP download, here is a video with new function.
(view in My Videos)
AdamGebhart
Thanks @Brian_McLeer for getting that updated so quickly!  I loaded into an app and in very brief testing it worked very well.  Thanks again.
KeyHunter
Brian,
Great work on this tool as well. I am updating our Board of Assessors internal site. They have been using the tool for a couple of months and have received feedback on the desire to delete segments, without deleting the whole list of segments.
I see the 1/28/26 release to edit vertices, and hope you're ahead of me, and this will meet that need. I will be downloading and testing this week, but thank you in advance if this meets users' needs!
Brian_McLeer
Thank you @KeyHunter, I don't think there would be a straightforward way to delete segments. Say if there are 4 segments and someone deletes wants to delete segment  2, it would create a multipart feature. Let me know if the editing vertices update helps.
AdamGebhart
@Brian_McLeer Hi Brian.  Our users have tested this about a little bit and love it.  Thanks again for sharing it and for making the previous updated.
One question they had is if there is the ability to edit the shape or text symbology to another color or colors.  Or can the user set the colors before drawing?  I'm not seeing those options in the configuration pane.
Brian_McLeer
@AdamGebhart thank you for the compliments. There is not a way to edit text, colors, etc. within the widget. The developer can define the color sequence in settings, but that is about the furthest it can go for color management.
In creating this widget vs the Advanced Draw widget I wanted to keep this measurement focused, while I admit there are many similarities between this one and the draw widget. I think when you get into the customization of label font, size, color, changing geometry color, using the Advance Draw would be more appropriate for more advanced customization.
AdamGebhart
@Brian_McLeer Thanks for the explanation and for referring me to the Advanced Draw widget.  I'll give that a try next week and show our users.
ncramer11
Fantastic work, @Brian_McLeer! The level of customization here is incredible. This brings us one step closer to a proper Traverse tool for our county.
We’ve been using your Advanced Draw widget and find the ability to add custom units (like chains and rods) indispensable for historical work. Would it be possible to add a similar custom unit feature here?
Thanks for the constant updates!
Brian_McLeer
Thank you @ncramer11 . I could look at adding custom units in settings that can be set up by developer and an option to add it to linear and area drop down lists if configured via settings.
Brian_McLeer
2/26/2026:
Brian_McLeer
Brian_McLeer
Pei-SanTsai
@Brian_McLeer, I'm on ArcGIS Enterprise 11.5 and will be using ExB Developer Edition 1.17.  Will I be able to use  enhanced-measurement_1.19 & draw_advanced_3.1?  I'm planning to deploy these custom widget on the web server and register with Portal.  I do plan to upgrade to ArcGIS Enterprise 12.1 at the end of the year.  Thank you in advance.
Brian_McLeer
Hello @Pei-SanTsai. I can't guarantee the widgets are backwards compatible. That being said, I can tell you for my setup I am on version 11.5 of Enterprise and using the most current version of Developer Edition 1.20. I would recommend at least trying to use 1.19, but if you can use 1.20 and test different versions. I can tell you that 3.2 of Draw will not work on 1.19 or earlier.
Pei-SanTsai
@Brian_McLeer Thank you very much for the info regarding your set up.  I think I'll try the most current version of DE 1.20 as it's only about 6-7 months away for me to upgrade to 12.1.
Contributors
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
