EB Custom Widget not able to connect to the layer from the map or directly to a layer
1216
07-15-2025 01:34 PM
AbiDhakal
Dear GIS friends,
I'm working on a custom widget, but I am not able to connect the widget to the map layers. When I add the widget to a map I get this error:
Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=undefined&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings
Please help I'm naive.
Please see attached files if it helps.
I have done a lot of npm start on the server and client.
Thank you,
Abi
JeffreyThompson2
MVP Frequent Contributor
That error doesn't mean much without context. It's probably a syntax error or an improper import statement. Can you post your code?
GIS Developer
City of Arlington, Texas
AbiDhakal
I can certainly do that. Please see attached.
Thank you very much.
JeffreyThompson2
Are you having issues at runtime or in the Build Mode? The most questionable thing I am seeing is in the Setting.tsx. I don't think it is valid to assign and deconstruct in the same statement.
  const { useMapWidgetIds = [], useDataSources = [] } = props
This line should probably just be this:
  const { useMapWidgetIds, useDataSources } = props
GIS Developer
AbiDhakal
I appreciate your response very much.
It is happening during runtime. I tried your suggestion and I still get the same error in runtime.
Abi
