Issues deploying ElectricFoundationV2.2
903
06-12-2023 11:27 PM
Labels (2)
Jan_Creupelandt
I attempt to deploy the ElectricFoundationV2.2 on an Enterprise geodatabase.
First, I noticed the asset package that is delivered in the solution doesn't contain any data, so I exported the deployed Utility Network from the file geodatabase to an Asset Package. This took 17hours to export. Don't know why it takes so much time, as I remember in the past this could easily be done in 2hours. However, I have an Asset Package containing the sample data now.
Second, I tried to deploy this asset package to an Enterprise geodatabase. I took the D_Rename and D_Configurations from the Balanced fgdb. Herewith my python script;
arcpy.pt.AssetPackageToUtilityNetwork(
asset_package=r"E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\Electric_AssetPackage_With_Data.gdb",
domain_networks="Structure;Electric",
in_utility_network=r"E:\GISFolder\Connections\ElectricFoundation_v2_2\unadmin@electricfoundation_v2_2.sde\electricfoundation_v2_2.unadmin.UtilityNetwork\electricfoundation_v2_2.unadmin.Network",
load_data="INCLUDE_DATA",
analyze="ANALYZE",
configurations="'Transmission (Base)';'Transmission Stations';'Transmission Support Structures';'Centralized Generation';'Transmission Functional Equipment';'Subtransmission (Base)';'Subtransmission Stations';'Subtransmission Functional Equipment';'Subtransmission Other Structures';'Balanced Distribution (Base)';'Distribution Stations';'Distribution Overhead Equipment';'Distribution Underground Equipment';'Distribution Other Structures';'Distributed Generation';'Distribution Functional Equipment';'Secondary Balanced (Base)';'Secondary Distributed Generation';'Secondary Stations';'Secondary Structures';'Secondary Functional Equipment';'Secondary Overhead';'Secondary Underground';'Secondary Aerial Structures';'Remove All LV DC';Ground;'Underground Structure Network';'Miscellaneous Structures';'Communications Equipment and Structures';'Metric Units';'Engineering Analysis Support';'Alternate Switching States'",
rename_field="Balanced",
post_process="NO_POST_PROCESS"
When starting the script, I get this warning and error messages, resulting in "Apply Asset Package Failed"
Start Time: Tuesday, June 13, 2023 6:21:59 AM
ArcGIS Pro 3.1.2.41833
untools 3.1.0
Executing from ArcGIS Pro, 6 map(s), activeMap = False
Parallel processing enabled: 6
Asset Package schema version: 3.1
Staging directory -- E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1066
ERROR 002580: The asset type domain is already assigned to another class or asset group.
WARNING 000952: Failed to execute (AssignDomainToField).
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1071
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1076
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1081
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1086
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1091
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1096
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1101
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1106
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1111
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1116
E:\GISFolder\ArcGIS Solutions\ElectricUtilityNetworkFoundationV2_2\Database\AP_Workspace\xml\StructureJunction_1_Fields-Subtypes-CV.xml:1121
@mmiller and @JohnAlsup, any idea why this failed?
Jan
MikeMillerGIS
Esri Frequent Contributor
There was a change in ArcGIS Pro, that gp tools evaluate closed maps. This is causing the performance issue and the corruption you are seeing in apply. They have reverted this change in 3.2, not sure when it will make a patch. For now, it is best to use a project with no maps for any asset package operations.
MikeMillerGIS
Jan_Creupelandt
Thanks Mike, will try this.
