Step 6: Enrich Data With Demographics
1524
04-23-2022 12:11 AM
IfeanyiPeterEzealaji
Good day all, please I'm in section two of the training and I'm stuck under step 6. The problem is that i couldn't find the "Analysis or Perform Analysis Button". Can someone help me out?
KatieSmith
Esri Alum
Hi @IfeanyiPeterEzealaji, I am just now seeing this, so apologies for the delayed reply. Is this for the Going Places with Spatial Analysis MOOC? We recommend you search within the MOOC forum to see if anyone else has experienced a similar issue and found a solution. If not, please post your question there. Perhaps you've already finished the course by now, but if not, please know that course access ends tonight at 11:50 pm (PT). Hope you enjoyed the MOOC!
Katie Smith | Principal Marketing Communications Specialist | Training Services
KatieSmith
Esri Alum
JoeSuarez
It would be helpful to know which specific training or software you are referring to, as the steps and buttons may vary depending on the context. However, here are some general tips that might help you with a faster b2b contact enrichment:
  1. Make sure you are in the correct section or module of the training. It's possible that the button you're looking for is located in a different section.
  2. Check if there are any prerequisites or requirements that you need to fulfill before you can access the analysis or perform analysis button. It's possible that you need to complete certain tasks or exercises before the button becomes available.
  3. Try searching for the button using the search function of the software or training platform. This can help you quickly locate the button if it's hidden in a sub-menu or if it's labeled differently.
  4. If you're still unable to find the button, try reaching out to your trainer or mentor for assistance. They may be able to provide additional guidance or clarify any confusion you have about the training.
I hope these tips help you locate the analysis or perform analysis button. Let me know if you have any further questions!
