Processing SAR Data in ArcGIS Notebooks - Error Step 7
1580
06-02-2025 11:51 AM
AmjadAlmarwani
Hello!
I'm currently working on step 7 of the "Processing SAR Data in ArcGIS Notebooks" course. I'm trying to run the Python code provided to download the updated orbit file for Sentinel-1 GRD data. However, the code is not working for me, and I keep getting the following error:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 003514: The input is not a radar dataset - radar metadata is missing.
Failed to execute (DownloadOrbitFile).
I've checked the folder structure of the .SAFE file, and everything appears to be in place. I tried using both the Python notebook and the Geoprocessing pane, but I keep encountering the same error.
I'd appreciate any guidance or suggestions.
Thank you!🌼
Suzanne-Boden
Hi @AmjadAlmarwani , sorry to hear you're having an issue. If you're still experiencing it, please report it in the Help tab inside this ArcGIS Lab so our team can help you troubleshoot.
JulienVadnais
It seems that Sentinel-1C products are raising this error for all SAR tools, whereas Sentinel-1A/B work fine.
"Error 003514 The input is not a radar dataset - radar metadata is missing"
Could this issue please be forwarded to ArcGIS Pro technical teams?
Julien Vadnais
Dpt of Earth Science
University of Bergen, Norway
Laura
by MVP Regular Contributor
I'm getting this error as well.
JulienVadnais
Hi Laura,
They should have fixed it in version 3.5.3. If you can update the software it might work.
Laura
Hm, I'm using 3.6. So far support hasn't been able to figure it out either.
