Inheritance in webmaps
1702
08-19-2020 01:50 AM
leonoestergaard
Can webmaps inherit from other webmaps?
So if I have the following:
Can I create a webmap base and inherit from it like this?
Or how does webmaps share common functionality?
DerekLaw
Esri Esteemed Contributor
Hi Leon,
This is not supported. A web map cannot reference another web map. The system is not designed (nor meant) to work this way.
Hope this helps,
DerekLaw
Hi Leon,
Hope this helps,
leonoestergaard
Hi Derek
Thank you for the answer. Not what I hoped for, but still thank you
