I have a Garmin GPSMAP 64st that I have recently wanted to export the way points and the track off of and add it to map. I have Arc Desktop 10.5 installed and the problem that I am looking for direction on is what is the best way to clean up the track lines? I have tried searches and everything that I try seems to be a dead end. Also, I have tried to edit and split the lines that overlap each other and for some reason it will not allow me. Any help or suggestions would help.
John Payne
