Change Line color from blob field in arcgis represenatation
935
07-19-2016 05:06 AM
AhsanMukhtar1
I have create a representation rule that has a line with black color which is default color. i have a field named "color" with blob type. Now from "Display override field " I have changed the field of line color to that blob field, so now it means that the changes in that blob field would directly effect the changes in line color. I added a red color blob image in that field for a particular line. But it did not effect the color of line. Am i doing something wrong. i added blob image into table through oracle, as my data is in oracle. In what format the data i needed to add in order to change the color of line dynamically.
Best Regards,
Environment: oralce 11g
ARcGIS 10.4.1
