GIS Fundamentals Exam or ArcGIS Pro Foundation
1699
10-06-2023 02:02 PM
JRosalesGIS
Exam Comparison: GIS Fundamentals Foundation 2024 and ArcGIS Pro Foundation 2101
Not sure which exam is best for you? When determining which exam level and version is best for you, open the Exam Information Guide from the Exam Details Page and compare the exam information. If you’d like to personal your approach, read this blog: A Personalized Approach to Exam Selection.
  1. Experience: The GIS Fundamentals exam is designed for candidates with 150 hours of GIS coursework or 3-6 months of GIS workplace experience and the ArcGIS Pro exams validate the skills and experience with Esri software at between 0-2 years’ experience.
  2. Exam Duration: The GIS Fundamentals  Foundation exam allows for 1 hour, and 30 minutes and the ArcGIS Pro Foundation exam duration is 1 hour, and 30 minutes.
  3. Exam Blueprints are significantly different (table below) and shown on each Exam Information Guide: GIS Fundamentals Foundation and ArcGIS Pro Foundation.
Data Discovery - 35%
ArcGIS Fundamentals - 18%
Identify steps to add data
Identify the use and purpose of the ArcGIS components
Identify data types
Recall procedural concepts necessary to work with ArcGIS Pro and ArcGIS Online
Identify coordinate systems
Apply concepts required to select appropriate ArcGIS applications for a given workflow or use-case
Define fundamental GIS concepts
Discover content in ArcGIS Online
Describe how to use map navigation tools
Processing and Analysis - 22%
Data Management - 34%
Describe how to use attribute tables
Identify how to access data properties
Recall how to perform analysis
Describe the purpose of item details, item descriptions, and metadata
Recall how to edit local data in ArcGIS Pro
Identify the correct procedures necessary to create a file geodatabase and a feature class
Identify supported ArcGIS data formats
Recognize the different data management techniques in ArcGIS Pro and ArcGIS Online
Determine the appropriate method for managing tabular data
Identify basic editing workflows that are necessary to create or modify features
Recognize the purpose and characteristics of geographic and projected coordinate systems
Mapping and Visualization - 25%
Mapping & Visualization - 23%
Identify steps to change Basemaps
Recall how to apply and modify symbology
Recognize how to represent and style data
Determine the appropriate method to modify layer properties
Identify steps to generate labels
Identify the steps necessary to label features
Identify layer properties in ArcGIS Pro and ArcGIS Online
Identify the use and effects of scale on a map
Identify the steps necessary for adding data
Demonstrate an understanding of how to configure map properties
Managing and Sharing Content - 18%
Sharing Data - 11%
Describe how to validate a map for sharing content from ArcGIS Pro
Recall how to discover content from ArcGIS Online
Organize content in ArcGIS Online
Determine the appropriate method to share content from ArcGIS Pro and ArcGIS Online
Identify elements of ArcGIS Online
Performing Analysis - 14%
Determine the appropriate workflow using proximity and overlay tools
Determine the correct workflow to select features interactively, using attributes or by location
Recall methods to find geographic locations
Best to you on your Certification Journey!
About the Author
I manage the Esri Technical Certification Program, engaging with Esri-certified subject matter experts to create high-stakes certification exams.
