ArcGIS Enterprise and Antivirus Software
12596
16
08-21-2024 07:37 AM
Kathleen_Crombez
I am looking for a new Antivirus Solution for ArcGIS Enterprise.
Let me know what you are using!
SStopyak_BruceHarris
I saw people posting that Sophos and Crowdstrike are good. Please do not believe it. I have seen both render Portal broken and inaccessible. Those are literally the biggest two to absolutely avoid. Just run Defender. Any AV could mess up your enterprise, honestly and all of them will slow it down.
CodyPatterson
MVP Regular Contributor
Hey @Kathleen_Crombez
My company uses SentinelOne as AV, personally, I've had no issue installing and using the various ArcGIS Enterprise software while this AV is active. I previously worked for IT in the same company, and have found the AV to be quite reliable, I would personally recommend it.
Cody
Kathleen_Crombez
@CodyPatterson-
Thank you for the information!
Did you have to configure all the exceptions as recommended in the ArcGIS Antivirus Guidance
From my past experience most anti-virus software is destructive to the ArcGIS Enterprise suite and makes installation/upgrades downright impossible while the software is active. So I am really happy to receive a recommendation from someone with both GIS and IT experience.
Thank you again!
Kathleen
CodyPatterson
Currently, none of the exceptions were made in my AV when assembling ArcGIS Enterprise. We do not exclude any file from being scanned and these scans that take place have not caused any significant strain on the servers that host the environment. I can definitely understand an AV causing issues, as I've worked with quite a few, but this one is quite straight forward! I've had no issues with false positives as well.
Cody
GregoryCarson
We have used Crowdstrike in the past and now use Cortex without any issues.
Kathleen_Crombez
@GregoryCarson-
Thank you!
Was there a reason you switched from CrowdStrike to Cortex? Do you notice any benefits or downsides from one to the other in comparison?
Any issues with installation or upgrades?
Thanks again!
Kathleen
GregoryCarson
We were purchased by a bigger company and change to Cortex was due to parent company.  I did not do anything to our Esri servers with Crowdstrike or Cortex, as neither of them caused any issues.  (We have numerous ArcGIS servers (10.8.1 to 11.3) federated to our 11.3 portal)
MarceloMarques
@Kathleen_Crombez
Sophos, CrowdStrike
New Technical Paper: Considerations for configuring antivirus software for ArcGIS Enterprise hosts (...
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
Kathleen_Crombez
@MarceloMarques-
Thank you for the link. I have seen this post in the past but they have updated the link for the ArcGIS Antivirus Guidance document.
Are Sophos and CrowdStrike both tested and used in production at ESRI?
Thanks again,
Kathleen
MarceloMarques
Yes, we use it internally and have customers that use it too.
Your IT department will have to evaluate that but usually price is the decision factor.
