there were a few different things going on causing problems.
1. your own service doesn't support making CORS requests. thats okay, but its necessary for you to pass through `useCors: false` in your own constructor
2. even though your service advertises itself as wkid: 3857, its actually using a custom XY for its origin, which is problematic when the internal API attempts to translate the global LODs the service is missing.
3. there was a bug in esri-leaflet that led to us attempting to override custom LODs provided in code when we recognized the coordinate system as web mercator. (i fixed that here and published v2.1.2).
all that said, in our latest release, we display the service correctly, but its still up to you to describe the custom projection in your own code.
var crs = new L.Proj.CRS("EPSG:3857","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs", {
origin: [-20037700, 30241100],
resolutions: [
611.4962262813797,
305.74811314055756,
152.87405657041106,
var map = L.map('map', {
crs: crs
}).setView([32.2217, -110.926], 2);
L.esri.tiledMapLayer({
url: 'https://maps2.tucsonaz.gov/arcgis/rest/services/BaseMaps/gisBaseMap_Topo/MapServer',
useCors: false
}).addTo(map);
live sample: http://jsbin.com/yovezox/edit?html,output
(based on the sample in our documentation here)
