Please help me
public class MainActivity extends AppCompatActivity { Button btn; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); btn=(Button)findViewById(R.id.button); } public void btnClick(View view) { Intent intent = new Intent(MainActivity.this,MapActivity.class); startActivity(intent); } }
MapActivity:
public class MapActivity extends AppCompatActivity { private static final String TAG = MainActivity.class.getSimpleName(); private static String extSDCardDirName; private static String filename; private static String mmpkFilePath; private MapView mMapView; private MobileMapPackage mapPackage; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); // get the directory extSDCardDirName =Environment.getExternalStorageDirectory() + File.separator + "mmm/"; // get mobile map package filename filename ="maps.mmpk"; // create the full path to the mobile map package file mmpkFilePath = extSDCardDirName + filename; Log.d("FilePath", mmpkFilePath); // retrieve the MapView from layout mMapView = (MapView) findViewById(R.id.map); loadMobileMapPackage(mmpkFilePath); }private void loadMobileMapPackage(String mmpkFile) { // create the mobile map package mapPackage = new MobileMapPackage(mmpkFile); // load the mobile map package asynchronously mapPackage.loadAsync(); // add done listener which will invoke when mobile map package has loaded mapPackage.addDoneLoadingListener(new Runnable() { @Override public void run() { // check load status and that the mobile map package has maps if (mapPackage.getLoadStatus() == LoadStatus.LOADED && !mapPackage.getMaps().isEmpty()) { // add the map from the mobile map package to the MapView mMapView.setMap(mapPackage.getMaps().get(0)); mMapView.setAttributionTextVisible(false); } else { // log an issue if the mobile map package fails to load Log.e(TAG, mapPackage.getLoadError().getMessage()); } } }); }}
Error is:
04-15 12:00:43.653 7426-7426/ com.mytest.mymap E/AndroidRuntime: FATAL EXCEPTION: main
Process: com. mytest.mymap, PID: 7426
java.lang.NullPointerException: Attempt to invoke virtual method 'void com.esri.arcgisruntime.mapping.view.MapView.setMap(com.esri.arcgisruntime.mapping.ArcGISMap)' on a null object reference
at com. mytest.mymap.MapActivity$1.run(MapActivity.java:77)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:211)
at android.app.ActivityThread.main(ActivityThread.java:5389)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1020)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:815)
When the following condition is true, the mapPackage value is not null
My mistake is copy code from mainactivity to mapactivity !!!
replace with
protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_map);
