I am getting an error in intersect process..
667
01-30-2019 03:25 AM
SOMNATHBAR
I want to process some raster layer through the different processes in arcpy. but I am getting an error in intersect like .........
File "C:\Users\Lrm\Desktop\Pyy.py", line 44, in <module>
b = arcpy.Intersect_analysis("i 0;taluk 1", inMemInt, "ALL", "", "INPUT")
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\analysis.py", line 289, in Intersect
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset i 0;taluk 1 does not exist or is not supported
Failed to execute (Intersect).
Below I paste the code, please look into the problem
# -*- coding: utf-8 -*-
# Pyy.py
# Created on: 2019-01-30 14:10:35.00000
# (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy,os
from arcpy import env
from arcpy.sa import *
arcpy.env.overwriteOutput= 1
arcpy.CheckOutExtension("Spatial")
env.workspace = "E:\\PhD.Progress_1\\climatic data\\Pre\\All"
# Local variables:
Taluk = "E:\\PhD.Progress_1\\UK_HP_SKM\\UK_HP_Taluk.shp"
print Taluk
Rfiles=arcpy.ListRasters('*', 'tif')
print Rfiles
for cl in Rfiles:
print cl
print("processing2:"+cl)
fileroot1= cl[0:(len(cl)-3)]
# Process: Raster to Point
points = "in_memory/Points" + fileroot1
a = arcpy.RasterToPoint_conversion(cl, points, "Value")
print "''''''''''''''Point'''''''''''Done'''''''''''''''''''''''''''"
print arcpy.GetMessages ()
for i in a:
print i
print("processing3:"+i)
fileroot2= i[0:(len(i)-3)]
#Taluk = "E:\\PhD.Progress_1\\UK_HP_SKM\\UK_HP_Taluk.shp"
taluk = r"E:/PhD.Progress_1/UK_HP_SKM/taluk.shp"
print taluk
inMemInt = "in_memory/Intersect" + fileroot2
# Process: Intersect
print "'''''''''''''''Ins'''''''''''Done'''''''''''''''''''''''''''"
for j in b:
print j
print("processing4:"+j)
fileroot3= j[0:(len(j)-3)]
dis = "in_memory/dis" + fileroot3
# Process: Dissolve
c = arcpy.Dissolve_management(j, dis, "NAME_3", "GRID_CODE MEAN", "MULTI_PART", "DISSOLVE_LINES")
print "'''''''''''''''Dis'''''''''''Done'''''''''''''''''''''''''''"
for k in c:
print k
print ("processing5:" + k)
outdir4 = 'E:\\PhD.Progress_1\\climatic data\\Pre\\Xl_Taluk\\'
pli_save = outdir + fileroot4 +'xls'
arcpy.TableToExcel_conversion(k, pli_save)
print "'''''''''''''''XL'''''''''''Done'''''''''''''''''''''''''''"
print "'''''''''''''''All Has Done'''''''''''Done'''''''''''''''''''''''''''"
