Hello, I conduct frequent field inspections for Weights and Measures, recording multiple test results at the same location. We have InspectionSites (geopoint) where multiple related ScaleTests (nested table) need to be recorded frequently. Currently, for each test entry, users have to relaunch the form from the web app, making the process slow and inefficient.
How can I streamline data collection for ongoing field inspections of multiple related tests at the same location using Survey123, avoiding the repeated form launches required in the standard web application setup?
In scenarios involving field inspections where multiple tests need to be recorded, the recommended approach involves using Survey123's repeat functionality along with URL parameters to edit related tables directly from the web application while preserving the parent layer.
Steps to achieve the workflow:
var urlsource = 'arcgis-survey123://?';
var params = {
itemID: '5abd60afec24471f93cb4cc971357f6a', // Survey123 Form Item ID
'field:Name': $feature.Name, // Populate with the related feature's name
action: 'edit', // Set the form to edit mode
update: true, // Enable update mode for related records
filter: 'field:GlobalID:' + $feature.GlobalID, // Filter to match the correct record based on GlobalID
q: 'where=GlobalID=' + $feature.GlobalID // Query string to target the exact record
return urlsource + UrlEncode(params);
This URL will open the form with the current inspection data, allowing multiple entries to be captured in one session. [Note: As improper URL formatting may cause the Survey123 app to run into hiccups, encoding is a safe bet]
You may proceed to conduct field tests to ensure that the form behaves as expected: launches correctly, allows repeated entries, and saves updates to the related table without error. With the expected workflow, the Field Collection process would be simplified by enabling repeated capture of information via related table for selected location.
