Password/GPT.xml Password Reset Issue
2938
06-11-2013 05:47 AM
ArthurMcDonough
Hello All -
I am trying to simply change my password in the gpt.xml file (using simple authentication) and am having no luck. When I change the password I go back to the login page to login and the password will not work. When I try using the old password, it works fine. What is going on? is there a cache or something that is holding on?
Also, I tried to switch to LDAP authentication, so I tried commenting out the simple authentication and it still worked?? Any suggestions would be greatly appreciated.
RichardKachelriess
Hi Artie123,
It sounds like you didn't restart Tomcat after changing the gpt.xml files. Any changes that you make to the Geoportal's configuration won't take effect until you restart the Tomcat server.
If that didn't work, reopen the gpt.xml file to see if your new password is still there. If your old password is there instead, the gpt.xml file might be set to Read Only or you might have some kind of permission issue with changing the file.
I hope that this helped.
Richard
MartenHogeweg
Please note we're not actively monitoring this forum. For Geoportal Server related questions or discussions, please use our discussion forum on github (where we host geoportal server source code): https://github.com/Esri/geoportal-server/issues
rodickwillision
I read your problem. Your are facing problem for Password Reset Issue. I send a blog post you can read this post and I believe that your problem will be solve. Active Directory Self Service secure, and web-based Active Directory self service software, They can permit the users and update personal information in Active Directory, reset password, and unlock account. More information read this post : http://activedirectoryselfservice.blogspot.com
