Installing ESRI Geoportal on same server as ArcGIS Server installation
1841
06-04-2012 10:44 AM
NatalieO_Toole
Is it possible to install the ESRI Geoportal Server on the same server that ArcGIS Server is installed on?
Are there any issues? Do I have to change the port on the server that ArcGIS Server uses?
Are there any other issues.
My version 9.3 ArcGIS Server is installed on a Windows 2003 Server operating system.
I would like to put ESRI Geoportal server on the same server box using the same operating system.
Please let me know.
Thank-you.
Nat
MartenHogeweg
See my response at: http://forums.arcgis.com/threads/59179-ArcGIS-Server-9.3-ESRI-Geoportal-Server-1.2-compatibility?p=2....
especially if you have the .NET version of server this should not be an issue as you won't run into having multiple Java versions.
