Geoportal login issues
6505
02-12-2015 09:50 AM
AlexGole
Hi all,
I am currently try to install geoportal on my machine and everything seems to work great besides my login.
Here is my config:
PostgreSQL 9.1.25
Java 7
Geoportal 1.2.5
Apache Tomcat 7.0.5
PostgreSQL driver for apache Tomcat 7 “postgresql-9.1-902.jdbc4.jar”
geoportal xml:
<!-- Context configuration file for the Geoportal Web App -->
<Context docBase="geoportal" path="/geoportal" debug="0" reloadable="true" crossContext="true">
          <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource"
                 driverClassName="org.postgresql.Driver"
                 url="jdbc:postgresql://db_server:5432/geoportaldb"
                 username="geoportal"
                 password="Alex9200"
                 maxActive="20"
                 maxIdle="10"
                 maxWait="-1" />
         </Context>
Here is the message I get:
"Your username or password was not valid, please try again... "
Any idea why? I should be able to login the admin page.
Thank you,
Alex
MartenHogeweg
hi, have you configured the simple authentication model or LDAP?
AlexGole
That is where I got lost. I first set it up as "simple authentication model" then changed to LDAP. It now works great! I love this application and I am spending some time configuring it in order to eventually show it to my coworkers.
I have a completely different question (frequently asked by my co-workers) that i am trying to elucidate:
What's the difference between Portal for ArcGIS and Geoportal Server (besides the look and feel/usability)? There is not much documentation on it. Does Geoportal Server have functionalities that portal does not have (metadata?)?
I am going to implement either one or the other (or both?).
Thank you for your help,
Alex
MartenHogeweg
alright. don't hesitate to join the discussion on the github forum if you have questions or suggestions:
Issues · Esri/geoportal-server · GitHub
ErikLima
Can you get the gpt.xml to we view?
