I am trying to edit metadata from the Geoportal. The Geoportal right now has several .xml files that are actual metadata and also a couple of dummy metadata records I created in the Geoportal's metadata editor just to test things. When I try to use the metadata editor in the Geoportal to edit metadata, I get a dialog box that says, "The XML root element does not match the editor definition." Does anyone know what that means? It won't let me edit. I can create metadata in the Geoportal but I get this error message when I try to edit it. I get the same error when I try to edit the "real" metadata files I had loaded into the Geoportal.
