Created only one metadata table.
722
04-06-2010 07:14 PM
sher_vinchua
I am currently setting the Metadata Server 9.3 on one server while the ArcSDE is at another server. When I started the MetadataServer service (I re-created the service using the sc command), it only created the GPT_META table. The other 4 tables GPT_METAD, GPT_METADR, GPT_METAR, GPT_METAU weren't created.
The error message is as below:
[Apr 6, 2010 6:24:32 PM][3628 5740 ERROR] Internal Error 38: (SE_layer_get_info) SDE Error -20 (Layer not found)  Please contact ESRI Technical Support.
[Apr 6, 2010 6:24:32 PM][3628 5740 ERROR] Internal Error 39: (SE_layer_get_info) SDE Extended Error 0 (Layer not found)  Please contact ESRI Technical Support.
I am using direct connection for the Metadata Server. Please advise? Thanks in advance.
