Compile geoportal.swf ?
1942
06-21-2011 11:53 PM
PhilippeSTEINMANN
I work with ArcGis 10 and Flex Viewer 2.3 and I want to add the Geoportal Search Widget for Flex for testing in my application.
I tried to compile with the source but I have This message in the Flash Builder 4.
[Bindable] on 'spatialReference' getter requires a locally defined setter. WMSLayer.as /FlexViewer/src/com/esri/gpt/wms line 1077 Flex Problem
1172: Definition com.esri.gpt.flexviewer.widgets could not be found. GptUserAlert.mxml /FlexViewer/src/widgets/GeoportalSearch line 38 Flex Problem
what's the problem ?
How do you do?
Do you have a link url to download the compile version swf ?
Thanks you very much
RamkumarNunduri
Hi Philippe,
I too got exactly the same problem. I am checking out to resolve it. By the way did you get any solution for the problem?
Please do reply.
Ramkumar.
PrestigeMakanga
Did any one of you guys manage to compile the Geoportal widget? If so, would it be possible to get a compiled version?
Regards
Prestige
