Creating Raster from Strava GPX points
2460
05-13-2020 01:41 PM
JohnnyHarley
Hello!
I am working on maybe an unusal project right now. I have downloaded a race route from my Strava account as a GPX file and then used the GPX to Points tool in Arc. What tool should I use that would and parameters so that this current point route (attached) could be converted into a straight DEM file. The current shapefile has a Z value field. I could convert this point shapefile into a line and then add a DEM online and visualize the elevation of the route from there but thought there might be a way to bypass that. Thanks!!
DanPatterson
MVP Esteemed Contributor
If the points are sequential along the route, perhaps just calculate the cumulative distance and the Z value into 2 fields and produce an X-Y graph.
Use
Python parser required.  For calculating the Z value into a field (type Double) use...
!Shape!.centroid.Z
and for the cumulative distance
Expression
dist_cum(!Shape!)
Code block
dist_cumu(shape)
input:      shape field
returns:    cumulative distance between points
expression: dist_cumu(!Shape!)
x0 = 0.0
y0 = 0.0
distance = 0.0
def dist_cumu(shape):
    global x0
    global y0
    global distance
    x = shape.firstpoint.X
    y = shape.firstpoint.Y
    if x0 == 0.0 and y0 == 0.0:
        x0 = x
        y0 = y
    distance += math.sqrt((x - x0)**2 + (y - y0)**2)
    x0 = x
    y0 = y
    return distance
Then you can use the two field for graphing inside or outside (Table to Excel tool, for instance)
... sort of retired...
