Where is the ArcGIS Solutions Button?
1544
11-06-2019 01:41 PM
DarrinBlaisdell1
I'm in the process of deploying and ran into a button not visible in ArcGIS Pro.  My Share tab doesn't have the ArcGIS Solutions button to click on?  Yes, I am logged into ArcGIS Online currently and have tried with a login to my local portal site also, no go.  Options?
Thanks in advance.
Darrin
samwilliamson_nz
Hey Darrin - Have you installed the add-in?
The ArcGIS Solutions Deployment Tool is an add-in to ArcGIS Pro that you need to download and install. Perhaps you need to grab that first. You can find it here: ArcGIS Solutions Deployment Tool | ArcGIS Solutions
Cheers,
Sam
DarrinBlaisdell1
Sam and Mark,
Yes, I found the ArcGIS Solutions Deployment Tool add-in.  One thing I have noticed is a tremendous amount of instability with ArcGIS Pro with the Add-In.  The number of crashes has been crazy!!  I reinstalled the software to try and reduce the number of crashes in Pro.  Didn't make much difference.
Thanks for your responses and help.
Darrin
MikeMillerGIS
Esri Frequent Contributor
You need to install the solutions deployment tool - ArcGIS Solutions Deployment Tool | ArcGIS Solutions
