Utility Network - Trace - Specific Phase
2211
11-01-2022 11:27 AM
ModernElectric
I am working on putting together a series of custom traces on my Electric Utility Network model in ArcGIS Pro from the Utility Network from ArcSolutions. I have multiple different feeder and upstream traces built. The only one I am having issues trying to figure out how to configure is be tracing the system on a particular phase designation and identifying the number of Transformers and Services that are on that phase. The goal is to do the starting point at the substation and trace down-stream on a specific feeder (subnetwork) to produce those results. Any advice?
Thank You in advance
DLee
Hi!
To achieve this you would need to set the following:
Output Conditions  to the phase you want
Output Asset Types to transformer and services,
Cheers!
Danny
DLee
Hi!
Cheers!
Danny
ModernElectric
Danny
Thank you for the quick reply. Very simple solution and probably helps me build a couple dozen different trace result tools knowing the very basic elementary features of the trace tool.
