Network Trace Widget for electric project
1743
03-28-2019 06:27 AM
EmilioGómez_Fernández
We have a question about the configuration of the Network Trace widget. We want to use it for a electric project.
We downloaded the witget Network Trace from GitHub and we have already implemented the widget in our WAB (developer edition).
To test the widget, we have used services from our Portal for ArcGIS. Specifically, the Naperville sample data from the electric utility network.
The problem arises in the first step of the configuration of the widget.
As we can see in the image, where it says Task URL, it asks us for geoprocessing. The problem is that we do not know which geoprocessing to enter or if we have to develop it ourselves and then publish it.
In the help of the widget configurator does not explain and there isn't any link.
Reading more about the subject, we have found documentation that we believe can help us (if that is what we need), which would be to perform the geoprocessing service ourselves, in the example that appears a water geoprocessing service, but we want it for electricity.
Could you clarify the line of work to introduce this service and be able to configure the new widget?
Is it possible to do this for an electric project?
My WAB (Developer Edition) is the latest version, 2.11 and Enterprise is 10.6.1.
Thanks in advance,
Luis
BrianBaldwin
Luis,
This is looking for a GP service that is hosted in your ArcGIS Enterprise instance. What you need to do, is run a trace in ArcGIS Pro on the Naperville data. After the trace runs successfully, go into the History and then share this result as a GP service. After it publishes, you can use this trace URL in the configuration.
Anything to add Previn Wong‌?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
JosephMarsh
Hi @PrevinWong1
Does the utility network trace for web app builder dev edition exist anywhere these days?  I have a customer that wants to pre configure traces and expose them in web app builder because they are not trying to replace WAB with Experience Builder or Instant Apps.
Joe
