Error code meaning in Electric utility code?
2594
05-01-2023 04:32 AM
GeorgeJones
Hi all, What does this table mean in term of dirty area errors?  For instance, what does 256 under error code indicate? Is it a reflection of a description and situation/error id in the utility network document found here: https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/about-error-features.htm
Tags (1)
RobertKrisher
An error code of 256 means an error id of 8, so that feature has a junction-edge error. The error ids are stored in the error code field using a bitmask, but if you look at those features using the popup tool the popup tool will automatically decode the bitmask to provide the corresponding error id and description. You can learn more about error codes, error ids, and the bitmask in the online help: https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/view-error-features.htm
RobertKrisher
