Asset package to Geodatabase failed
816
06-06-2024 09:08 AM
Kiril_Petkov
Hi, guys!
ArcGIS Pro 3.2.2.49743
untools 3.2.0
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 6
Asset Package schema version: 3.1
Staging directory -- C:\UN_V2_2\ZERO\AP_Workspace
The asset package has the following warnings (13/13):
                      Item                              Field   OID Value                                             Message    Level
0         ElectricAssembly  CustAtt_heightReferenceSurveyingZ  None  None  This field is too long for some database platforms  warning
1           ElectricDevice     TapchangerDriveDateManufacture  None  None  This field is too long for some database platforms  warning
2           ElectricDevice     Triggering_ShortCircuitCurrent  None  None  This field is too long for some database platforms  warning
3           ElectricDevice   CustAtt_typeCustomerServicepoint  None  None  This field is too long for some database platforms  warning
4           ElectricDevice     NoDomain_BreakingChInsulMedium  None  None  This field is too long for some database platforms  warning
5           ElectricDevice  CustAtt_heightReferenceSurveyingz  None  None  This field is too long for some database platforms  warning
6         ElectricJunction  CustAtt_heightReferenceSurveyingZ  None  None  This field is too long for some database platforms  warning
7   ElectricJunctionObject     TapchangerDriveDateManufacture  None  None  This field is too long for some database platforms  warning
8   ElectricJunctionObject     NoDomain_BreakingChInsulMedium  None  None  This field is too long for some database platforms  warning
9             ElectricLine  CustAtt_heightReferenceSurveyingz  None  None  This field is too long for some database platforms  warning
10       StructureBoundary  CustAtt_heightReferenceSurveyingz  None  None  This field is too long for some database platforms  warning
11       StructureJunction  CustAtt_heightReferenceSurveyingZ  None  None  This field is too long for some database platforms  warning
12           StructureLine  CustAtt_heightReferenceSurveyingZ  None  None  This field is too long for some database platforms  warning
C:\UN_V2_2\ZERO\AP_Workspace\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:255
ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 1 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).
C:\UN_V2_2\ZERO\AP_Workspace\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:288
C:\UN_V2_2\ZERO\AP_Workspace\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:321
ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 2 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).
C:\UN_V2_2\ZERO\AP_Workspace\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:364
Failed script Apply Asset Package...
Failed to execute (AssetPackageToUtilityNetwork).
Failed at 06 юни 2024 г. 17:41:16 (Elapsed Time: 8 minutes 43 seconds)
The table is present, the asset package is fine, the database is added to the project, no maps, new cloned environment. BUT- not working.
Please, help!
