Zoom to geoprocessor result
3944
7
08-18-2015 07:16 AM
DavidChevrier
   This should be pretty easy, but I've tried a bunch of stuff and cant get it to work.  How do I zoom to the newly outputted feature layer created by a geoprocessing service I create.  Here is the code for I use to create it.  I've tried the commented out method for setting the map's extent with the test1 and test2 variables, but it doesn't work.
-dave
function gpJobComplete(jobinfo) {
  //get the result map service layer and add to map
  gp.getResultImageLayer(jobinfo.jobId, null, null, function (layer) {
    layer.setOpacity(0.7);
    layer.id = "Created Mammal Data";
    map.addLayers([layer]);
  // var zoomLayer = map.getLayer('Created Mammal Data');
  // var test1 = webMercatorUtils.geographicToWebMercator(zoomLayer.fullExtent);
  // var test2 = zoomLayer.fullExtent;
  // map.setExtent(test1, true);
  map.on("layers-add-result", function (evtObj) {
    domUtils.show(dom.byId('legendWrapper'));
      if (!legend) {
        var layerInfo = array.map(evtObj.layers, function (layer, index) {
          return {
            layer: layer.layer,
            title: layer.layer.name
        legend = new Legend({
          map: map,
          layerInfos: layerInfo
        }, "legendWrapper");
        legend.startup();
TimWitt2
You could do something like this:
   function zoomToData (featureLayer) {
      // Zoom to the collective extent of the data
      var multipoint = new Multipoint(map.spatialReference);
      arrayUtils.forEach(featureLayer.graphics, function (graphic) {
        var geometry = graphic.geometry;
        if (geometry) {
          multipoint.addPoint({
            x: geometry.x,
            y: geometry.y
      if (multipoint.points.length > 0) {
        map.setExtent(multipoint.getExtent().expand(1.25), true);
Tim
DavidChevrier
Hmm.... this is failing with a weird "typeerror: d is not a function".  My guess is this is because I don't have a required statement.  This is just part of a big project, so here are the ones I have.  Am I missing one?
require(["dojo/dom",
                 "dojo/_base/array",
                 "dojo/date/locale",
                 "dijit/registry",
                 "esri/domUtils",
                 "esri/map",
                 "esri/dijit/Scalebar",
                 "esri/dijit/OverviewMap",
                 "esri/graphic",
                 "esri/layers/ArcGISDynamicMapServiceLayer",
                 "esri/layers/GraphicsLayer",
                 "esri/layers/FeatureLayer",
                 "esri/tasks/Geoprocessor",
                 "esri/tasks/FeatureSet",
                 "esri/dijit/Legend",
                 "dojo/parser",
                 "esri/symbols/SimpleFillSymbol",
                 "esri/symbols/SimpleLineSymbol",
                 "esri/SpatialReference",
                 "esri/dijit/PopupTemplate",
                 "esri/renderers/smartMapping",
                 "dojo/dom-construct",
                 "dojo/data/ItemFileReadStore",
                 "dijit/form/FilteringSelect",
                 "esri/graphicsUtils",
                 "esri/Color",
                 "dijit/layout/BorderContainer",
                 "dijit/layout/ContentPane",
                 "dijit/layout/AccordionContainer",
                 "esri/geometry/webMercatorUtils",
                 "esri/geometry/Geometry",
                 "dijit/form/Select",
                 "dijit/Dialog",
                 "dijit/form/Button",
                 "dijit/form/DateTextBox",
                 "dojo/domReady!"],
                 function (dom,
                           arrayUtils,
                           locale,
                           registry,
                           domUtils,
                           Map,
                           Scalebar,
                           OverviewMap,
                           Graphic,
                           ArcGISDynamicMapServiceLayer,
                           GraphicsLayer,
                           FeatureLayer,
                           Geoprocessor,
                           FeatureSet,
                           Legend,
                           parser,
                           SimpleFillSymbol,
                           SimpleLineSymbol,
                           SpatialReference,
                           PopupTemplate,
                           smartMapping,
                           domConstruct,
                           ItemFileReadStore,
                           FilteringSelect,
                           graphicsUtils,
                           Color,
                           BorderContainer,
                           ContentPane,
                           AccordionContainer,
                           webMercatorUtils,
                           Geometry) {
TimWitt2
"esri/geometry/Multipoint" is missing
DavidChevrier
Ah, I was forgetting that, but it still didn't work.  But I know why, it isn't a feature layer that is being returned, rather a ArcGISDynamicMayServiceLayer.  Any idea how to zoom to that?
TerryGustafson
Tim,
How did you determine he was missing the "esri/geometry/Multipoint" requirement?
TimWitt2
Terry,
The code that I posted needed "esri/geometry/Multipoint"
and once he posted his 2nd post I went through the list and looked if he has it already included in his current code.
DavidChevrier
Yes.  But I've decided to take the results and turn them into a featurelayer instead.  So I'm able to zoom using
var graphicsExtent = graphicsUtils.graphicsExtent(features);
map.setExtent(graphicsExtent);
