Using Arcade to View Photos in a related table via popup
2098
04-30-2021 04:07 PM
MeleKoneya
I'd like to show the photos, if any by a listing in the popup.    I have this so far, but can't get to the photo.
Any suggestions on how to get the related photo as a listing in the popup?
var relatedrecords = FeatureSetByRelationshipName($feature,"COREs_photos")
var cnt = Count(relatedrecords);
var result = "Related records: " + cnt;
if (cnt>0)
for (var row in relatedrecords) {
result += TextFormatting.NewLine + row.globalid;
return result;
Tags (1)
jcarlson
From my experience, getting Arcade to spit out a single URL, to a file or a web page, works just fine.
Returning a series of individual items, however, I don't think can be done. At least, not with a single expression.
- Josh Carlson
Kendall County GIS
XanderBakker
Esri Esteemed Contributor
Hi @MeleKoneya ,
As @jcarlson mentions an Arcade expression in a web map is not be able to return HTML with multiples hyperlinks (in ArcGIS Pro you can do this).
If the pop-up needs to show multiple attachments, the (New) Map viewer is able to do this. If you have multiple picture attachments they will show up in the pop-up:
You can enter the settings and switch off the list option to preview the pictures a bit bigger:
