Two questions: Elevation layer and production API
1079
9
06-10-2026 04:19 PM
Labels (3)
ElenaCourtney
I have two questions:
1. Do you have elevation data layer to add to the map for e.g. mountains or anything really above sea level?
2. My prototype goes through three stages: dev-stage-lab. Do I need to purchase API key to move it to lab (currently it is our prod environment)? We are planning on going into production within the next two-three months. What are the quotes and rules for free API vs paid one?
Thank you!
5 Solutions
GlenterpriseUK
Hi @ElenaCourtney,
1. It depends what you want to achieve as your end result. You can check this ArcGIS Elevation service | Esri Developer REST APIs documentation | Esri Developer or this Elevation Layers - Overview
2. You can use a combination of OAUTH/API Keys and benefit from the usage of Python API.
Hope it helps.
Regards,
Glen
GlenterpriseUK
GlenterpriseUK
Hi @ElenaCourtney,
ArcGIS Elevation service | Esri Developer REST APIs documentation | Esri Developer this is only available if you are using ArcGIS Location Platform and not ArcGIS Online.
Please see below:
Regards,
Glen
GlenterpriseUK
Hey @ElenaCourtney,
This is global coverage example Terrain 3D - Overview same applies when you use the ArcGIS Elevation service.
Regards,
Glen
GlenterpriseUK
In ArcGIS Online you have the Elevation Layers from the group that I shared.
In ArcGIS Location Platform you can use the Elevation Service.
GlenterpriseUK
Hi @ElenaCourtney,
Hope it helps.
Regards,
Glen
ElenaCourtney
Would #2 be free even in lab/production or will I have to purchase something? Thank you for your help!
GlenterpriseUK
Hi @ElenaCourtney,
OAuth and API Keys are included with any ArcGIS Online subscription
Tutorial: Create OAuth credentials for app authentication | Documentation | Esri Developer
Regards,
Glen
ElenaCourtney
Hi Glen,
another follow up question. For elevation pricing, it says 50K are free and then $1 for each 1000. Are 1000 hovers or clicks? What are they? Thank you!
GlenterpriseUK
Hi @ElenaCourtney,
Please see below:
Regards,
Glen
ElenaCourtney
Thank you! Are your services US based only or worldwide for elevation or anything else?
GlenterpriseUK
Hey @ElenaCourtney,
Regards,
Glen
ElenaCourtney
Sorry, you said this is only available when we are using location platform and not online platform. Do you mean that elevation is not available on the online platform? Can you please elaborate?
GlenterpriseUK
